System.MissingMethodException error when creating new document using C# VB2012
Options
I am trying to create new document using iManage extension library(iManExt.dll). It works in my local machine fine. But when I deploy that to other machine it doesn’t work even though all dll in there. I am getting following error from desksite
System.MissingMethodException: Method not found: 'System.Type System.Runtime.InteropServices.Marshal.GetTypeFromCLSID(System.Guid)'.
Following is my c# code for creating new document.
private IManage.IManDocument NewDocumentProfile(IManage.IManFolder aFolder, String aFileName)
//IManage.NRTDocument NewDocument;
IManage.IManDocument NewDocument;
IMANEXTLib.ImportCmd MyCommand = new IMANEXTLib.ImportCmd();
IMANEXTLib.ContextItems MyContext = new IMANEXTLib.ContextItems();
MyContext.Add("ParentWindow", Helper.GetActiveWindow());
MyContext.Add("ImanDestinationObject", aFolder);
//Optional Fields
MyContext.Add("IManExt.Import.KeepCheckedOut", 0);
MyContext.Add("IManExt.Import.FileName", aFileName);
MyContext.Add("IManExt.CalledFromIntegration", false);
MyContext.Add("IManExt.OpenCmd.NoCmdUI", false);
MyCommand.Initialize(MyContext);
MyCommand.Update();
//if we have an OK status, display the new profile screen
if (MyCommand.Status == (int)IMANEXTLib.CommandStatus.nrActiveCommand)
MyCommand.Execute();
//get the new iManage document object
NewDocument = MyContext.Item("ImportedDocument");
//NewDocument.Security.DefaultSecurity = SecurityType.nrPrivate;
//NewDocument = GetiManDoc(MyContext);
else
NewDocument = null;
return NewDocument;
Please help me...
//Optional Fields
MyCommand.Update();
else
NewDocument = null;
return NewDocument;
Please help me...
Judging by the error it's a .Net issue, check the destination has the same version installed:
http://stackoverflow.com/questions/12655236/excel-interop-missingmethodexception
Hope this helps0
- 109 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 122 Exstream
TeamSite Developer Resources
- Docker Automation
- TeamSite Add-ons
