Analytics
using switch statement
prashanth
i used the Switch/case statement to replace the value retrived from database with that of sensible text to be displayed in a field but its not working. I have used in the Expression builder iof the BIRT and also the Javascript engine in all the event handlers.
can anybody help me to solve this issue.
Thanks
Prashanth
rmurphy
Have you tried to change the values using the BIRT mapping capabilities? This allows you to specify a condition, and when the condition is met you can display a specified value.
To create a map, select the data element on the report, and in the Property Editor, select the Map tab.
Rob
