Gantt Chart using Chart engine api
Options
There are basically four steps to generating charts:<br />
A] Create the chart model<br />
B] Bind the dataset(s)<br />
C] Build the chart<br />
D] Render the chart<br />
Which step are you having issue with? <br />
The following document answers frequently asked questions on how to use the Charting Engine API<br />
<a class='bbc_url' href='http://www.eclipse.org/birt/faq/Charts_FAQ.doc'>http://www.eclipse.org/birt/faq/Charts_FAQ.doc</a><br />
AshwiniWarning No formatter is installed for the format ipb0 -
Thanks for your inputs Ashwini ...
I have used the chart_faq to generate Bar and Line charts ..... but I am having issue with defining and biding the dataset for the gantt chart.
I have created a ganttDataSet with an array of GanttEnty values , but i am kind of confused with which data set should be bound to x axis and which one to y axis ....
I have tried using ganttDataSet with the y axis , and NumberDataSet for X axis but it gives me kind of weird chart .....
Could you advise me some thing here .....0 -
Hi DevGulve,
Have you taken a look at the Chart Examples view within the BIRT Designer? It is available from the Eclipse menu at Window | Show View | Other... | Report and Chart Design. There are several different chart examples there. After you select one, you can open it and see all the code needed to generate that chart.Warning No formatter is installed for the format ipb0 -
Hi DevGulve:<br />
I have created a simple example and posted it on DevX<br />
<a class='bbc_url' href='http://www.birt-exchange.com/modules/vbulletin/../wfdownloads/singlefile.php?cid=2&lid=247'>http://www.birt-exchange.com/modules/wfdownloads/singlefile.php?cid=2&lid=247</a><br />
- 108 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 120 Exstream
