Mapping the output parameter to input parameter
hhohho Member
edited December 31, 1969 in Designing Analytics Reports
is there anyway to map a output parameter from one data set to a input parameter on other data set?
Thanks
  • ericsmithericsmith Junior Member
    If you are trying to create a parent-child type report, yes.
    In your second dataset, enter the where clause using the ? placeholder, then when you bind the dataset within the report, you can set the parameter = a value from your parent data set.
    I do this all the time for "sub reports" - for example when you want to display all orders for each customer etc.
  • hhohho Member
    I tried and I was able to pass the output params to input params
