use of chart Engine in java application
I m new to BIRT Chart .
I want to create chart by using birt chart in my java Application.
I created on class wich hav function for creating pieChart
and one class which loads PNG driver and create png image file of that chart
I included all .jar files from chart Engine and requered files from Report Engine
But i m getting exception
this is the exception
Mar 31, 2008 4:24:58 PM org.eclipse.birt.chart.util.PluginSettings instance
WARNING: Exception
org.eclipse.birt.core.exception.BirtException: Cant startup the OSGI framework
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:90)
at org.eclipse.birt.chart.util.PluginSettings.instance(PluginSettings.java:298)
at org.eclipse.birt.chart.util.PluginSettings.instance(PluginSettings.java:274)
at DataChartsViewer1.<init>(DataChartsViewer1.java:68)
at DataChartsViewer1.main(DataChartsViewer1.java:57)
Caused by: org.eclipse.birt.core.exception.BirtException: Could not find the Framework - org.eclipse.osgi
at org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OSGILauncher.java:95)
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:78)
... 4 more
what shd I do??????
Is any more Api's are required?????????
please help me...........
thnks
mann
WARNING: Exception
... 4 more
what shd I do??????
thnks
mann
Hi mann,<br />
Did you look at the required JARs list at the chart FAQ at:<br />
<a class='bbc_url' href='http://wiki.eclipse.org/BIRT/FAQ/Charts2.2#What_JARs_are_needed_on_the_classpath_to_deploy_the_Eclipse_Chart_Engine.3F'>http://wiki.eclipse.org/BIRT/FAQ/Charts2.2#What_JARs_are_needed_on_the_classpath_to_deploy_the_Eclipse_Chart_Engine.3F</a><br />
It has instructions for using the chart engine stand alone.Warning No formatter is installed for the format ipb0 -
hi virgil,
I got the solution .I just added the BIRT_HOME ="<Path of Report Engine>" in my Eclipse
setup i.e in VM arguments
Thanks a lot
But now i want create chart in web application
I got two solutions
I)Use of jsp tag lib to create chart which hav a input as xml file to create chart
II)Use of servlet to create chart by using agin xml file only
but i m not getting more examples on it, which create chart by using xml?????
what shd i do???
Is thr any othe way to do it????
I dont want to use BIRT WebViewer.
please help me.....
thanks
mann0 -
Hi mann,<br />
I answered some of these same questions at:<br />
<a class='bbc_url' href='http://www.birt-exchange.com/modules/vbulletin/showthread.php?p=31739'>http://www.birt-exchange.com/modules/vbulletin/showthread.php?p=31739</a>Warning No formatter is installed for the format ipb0
- 107 Developer Announcements
- 53 Articles
- 104 General Questions
- 141 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 76 Digital Asset Management
- 118 Exstream
