Are TOC and pagination related?
Options
I want to implement BIRT viewer like pagination functionality in the JSP pages of my webapp.
It is, however common knowledge that the BIRT engine will output HTML in a single file with repeated headers for every page.
I did some digging around and found a relation between TOC(Table of content) entries in the report and pagination. It is said the report viewer uses this technique to properly paginate HTML output. However, I am able to navigate my pages in the report viewer even though I dont have any TOC entries in my report(The TOC sidebar is blank).
What exactly is the technique used by the BIRT viewer to break up html that way?
How can I achieve this using the Report Engine API?
Thanks in advance,
birtnewbie.
Thanks in advance,
birtnewbie.
The BIRT Viewer does this by first doing a run task and then a render task. As part of the render task you can set a page number or a range of pages.
public class RenderTask {
public void runReport() throws EngineException
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setBIRTHome("C:birtbirt-runtime-2_2_1birt-runtime-2_2_1ReportEngine");
config.setLogConfig(null, Level.FINE);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
}catch( Exception ex){
ex.printStackTrace();
IReportDocument document = null;
//Open the report design
document = engine.openReportDocument("output/resample/mcb.rptdocument");
IRenderOption options = new RenderOption();
options.setOutputFormat("html");
//options.setOutputStream(arg0)
options.setOutputFileName("output/resample/mcb.html");
if( options.getOutputFormat().equalsIgnoreCase("html")){
HTMLRenderOption htmlOptions = new HTMLRenderOption( options);
htmlOptions.setImageDirectory("output/image");
htmlOptions.setHtmlPagination(false);
//set this if you want your image source url to be altered
htmlOptions.setBaseImageURL("http://myhos/prependme?image=");
htmlOptions.setHtmlRtLFlag(false);
htmlOptions.setEmbeddable(false);
}else if( options.getOutputFormat().equalsIgnoreCase("pdf") ){
PDFRenderOption pdfOptions = new PDFRenderOption( options );
pdfOptions.setOption( IPDFRenderOption.FIT_TO_PAGE, new Boolean(true) );
pdfOptions.setOption( IPDFRenderOption.PAGEBREAK_PAGINATION_ONLY, new Boolean(true) );
options.setActionHandler(new MyActionHandler());
IRenderTask task = engine.createRenderTask(document);
task.setRenderOption(options);
//task.setPageRange("1-3");
task.setPageNumber(3);
task.render();
task.close();
engine.destroy();
Platform.shutdown();
System.out.println("Finished");
Jason0
- 108 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 120 Exstream
