setting parameter
Options
Hi Dany,
Can you explain a bit more on what you need. If you want a list of parameters that come from a database made available to the users, then create a new parameter and select List Box or Combo Box...and then you can select a Dynamic list that comes from a database.
Otherwise, if you want your query to by filtered by another query, you may be better off using a nested Select statement in your SQL.Warning No formatter is installed for the format ipb0
- 108 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 120 Exstream
