Highlighting cell values in a library
I have created a library of data controls, which i use it in the report design. My next task was to change colours of the cell vaule to Red if it is less than zero value. How do i do this? The controls used in the reports are subclasses of the control in the library. I want to change the color of the control using code in the library.
Please help
Regards,
Lazeeboy
Please help
Regards,
Lazeeboy
You should be able to open the library, select the table from the report outline, select the cell you want to evaluate, and then add a highlight rule within the Property Editor. Screenshot enclosed.Warning No formatter is installed for the format ipb0
- 107 Developer Announcements
- 53 Articles
- 104 General Questions
- 141 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 76 Digital Asset Management
- 117 Exstream
