Label of legend entries
Options
I got some problems settings the labels in legend for a multi-line-chart.
I got multiple y-series with additional title information applied. When I use no grouping everything works fine and these titles are displayed...but when I add some additional grouping, only the grouping value is displayed. Is it possible to add the series title the legend entries. I tried to modify the values via script but I don't have information about the current series there...So, is there any chance to do this? I could imagine the following output in the legend.
X <series-identifier1> - <groupvalue1>
Or is it possible to add 2 legends. One for the symbols or different line styles to explain/identify the different y-series and one for the coloring to explain the groupings?
Ingo
Ingo
thanks for the quick answer, but unfortunately this doesn't solve my problem. In your example you have only one column for the values. In my case I got multiple which leads to multiple series...
For example, I got values from different places for specific items
Item; Time; value1; value2
A;500ms; null; 8
A; 700ms; 5;null
B; 750ms; 20; null
X-Axis -> Time
Grouping on Item
2 Series: 1. value1, 2. value2
Now, the legend should display:
<Symbol for series1> <Label for series 1 > <Item>
<Symbol for series2> <Label for series 2 > <Item>
Ingo0 -
Ingo,
I am not certain this can be done.
You could have the legend show up like
symbol for item a label for a
symbol for item b label for b
_________Separator
Where the separator shows up once and above is series one and below is series two.
Jason0 -
thats exactly what I got right now...but because if up to 6 series its hard to "remember" what one series represents...Is it possible to change the appearance of the separator so I could display a text for the series? ;-)
or is it possible to add another legend for the series?
Ingo0 -
Ingo,
This is a tough one. I suggest you log a bugzilla entry for this. You may also be able to add some script like
var series_number = 0;
function beforeDrawLegendItem(lerh, bounds, icsc)
if( lerh.getDataIndex() == 0 ){
series_number +=1 ;
var old_label =lerh.getLabel().getCaption().getValue();
lerh.getLabel().getCaption().setValue(old_label + " -- Ser" + series_number);
Jason0 -
Ingo,
Try something like:
importPackage(Packages.java.util);
importPackage(Packages.org.eclipse.birt.chart.model.data.impl);
importPackage(Packages.org.eclipse.birt.chart.model.component.impl);
importPackage(Packages.org.eclipse.birt.chart.model.type.impl);
var cm = icsc.getChartInstance();
var xAxis = cm.getAxes().get(0);
var yAxis = xAxis.getAssociatedAxes().get(0);
var yser1 = yAxis.getSeriesDefinitions().get(0).getDesignTimeSeries().getSeriesIdentifier();
var yser2 = yAxis.getSeriesDefinitions().get(1).getDesignTimeSeries().getSeriesIdentifier();
series_number +=1 ;
if( series_number == 1 ){
lerh.getLabel().getCaption().setValue(old_label + yser1);
}else{
lerh.getLabel().getCaption().setValue(old_label + yser2);
}0 -
since I haven't done scripting till now. Do I any more prerequisites to run this script? Do I need to copy more libraries or something like that to the tomcat?
As soon as I run the following method in the script I get a null-pointer-exception.
null ( 1 time(s) )
detail : org.eclipse.birt.chart.exception.ChartException
at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationImpl.onRowSets(ChartReportItemPresentationImpl.java:607)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.processExtendedContent(LocalizedContentVisitor.java:772)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.visitForeign(LocalizedContentVisitor.java:414)
at org.eclipse.birt.report.engine.content.impl.ForeignContent.accept(ForeignContent.java:59)
Caused by: java.lang.NullPointerException
at org.eclipse.birt.chart.script.ScriptHandler.convertException(ScriptHandler.java:1128)
at org.eclipse.birt.chart.script.ScriptHandler.register(ScriptHandler.java:1085)
at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationImpl.onRowSets(ChartReportItemPresentationImpl.java:465)
... 99 more
Ingo0 -
Okay,
it runs now. I don't know why but I created the same chart again and now it works, in generally. The problem I got now is, that in another chart, I got multiple y-Axis. I tried the following but unfortunately got always the same label...
var yAxis1 = xAxis.getAssociatedAxes().get(1);
var yAxis2 = xAxis.getAssociatedAxes().get(2);
var yser2 = yAxis1.getSeriesDefinitions().get(0).getDesignTimeSeries().getSeriesIdentifier();
var yser3 = yAxis2.getSeriesDefinitions().get(0).getDesignTimeSeries().getSeriesIdentifier();
series_number +=1 ;
switch ( series_number ) {
case 1: lerh.getLabel().getCaption().setValue(yser1 + " - " + old_label); break;
case 2: lerh.getLabel().getCaption().setValue(yser2 + " - " + old_label); break;
case 3: lerh.getLabel().getCaption().setValue(yser3 + " - " + old_label); break;
default:
Any suggestion? Thanks.
Ingo0
- 108 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 120 Exstream
