BIRT New Page Problem
I have a report with 2 levels of grouping along with data that varies from 1 to 40 rows.
Due to the way the data is organized I do not know if there will be 1 or more level 1 groupings, along with level 2 and finally detail lines.
It sounds like I'm out of luck, unless someone know a trick on how to keep track of print lines per page versus row counters.
thanks ahead of time for any consideration.
Thanks for your response but I dont think its a bug, more then a way to do something.
For example, to do a report I have to count the max # of rows that will fit on a page given I "may" have other titles, to whatever on the page.
So for my report, I have 7 as a row counter because there is so much stuff on only a single customer. So this means that most pages have alot of blank lines on then and looks really bad, while 1 page out of 200+ pages actually looks filled.
This seems by designed and I will be greatly appreciated when anything that is printed on a pages is counted as a row against the infamous "Page Break Interval".0 -
Is the desired behavior to output content to the end of a page (by size) instead of using row interval page break to split contents into groups that can fit into a page?<br />
Please check out the discussion and patch in this bugzilla to see if helps...<br />
<a class='bbc_url' href='https://bugs.eclipse.org/bugs/show_bug.cgi?id=223088'>https://bugs.eclipse.org/bugs/show_bug.cgi?id=223088</a>0
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 144 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 120 Exstream
