Analytics
BIRT PDf report is not showing in IE 7.0 but works in Fire Fox
sriraj
I have a problem with PDF report on IE where as it works on FF.
We are using BIRT 2.2.0 engine pluged in to web application.
On IE 7 it gives blank window and no PDF comes up.Where as same URL works fine with firefox 2.0.0 giving proper PDF report.
It will be great if any one can point out where thing can go wrong.Appreciate if you could help me on this issue as early as poosible.
Thanks
cypherdj
I could be wrong, but this sounds a lot like a cross domain issue to me.<br />
Have a read through this article<br />
<a class='bbc_url' href='
http://thedesignspace.net/MT2archives/000472.html'>http://thedesignspace.net/MT2archives/000472.html</a><br
Hope that helps,<br />
Cedric
shahamar
Hi sriraj,<br />
I am facing the same which is reported in another thread <br />
http://www.birt-exchange.com/modules/vbulletin/showthread.php?t=10950'>http://www.birt-exchange.com/modules/vbulletin/showthread.php?t=10950</a><br
Can you just check it out and see if your facing it in same scenario or different.<br />
Thanks,<br />
Amar
