Difference between iServer(iPortal) and iServer Express ?
Options
The iServer Express does allow for open security, but does limit to a single volume. The iServer Express is a lighter weight implementation of the enterprise class Actuate iServer. The core differences between the iServer and the iServer Express are:<br />
iServer Express allows for a single volume (internal DB) for managing report designs and output.<br />
iServer Express support Information Objects and EII, but caching of Information Objects is reserved for the iServer.<br />
iServer Express is pre-configured to support up to ten report activities per second (run, view, page, interact).<br />
iServer Express can execute one batch report at a time.<br />
iServer Express runs only BIRT and e.Spreadsheet reports.<br />
iServer Express is supported on Window and Linux. iServer is supported on these plus AIX, Solaris, and HP-UX.<br />
iServer Express does not support clustering, failover, or advanced tuning and configuration<br />
To be clear, the iPortal is the end user interface for browsing, scheduing, running, and viewing reports that are in the iServer or iServer Express.<br />
More information about iServer Express can be found at:<br />
<a class='bbc_url' href='http://www.birt-exchange.com/modules/products/birt-report-server.php'>http://www.birt-exchange.com/modules/products/birt-report-server.php</a><br />
You can find out more about the iServer at:<br />
<a class='bbc_url' href='http://www.actuate.com/products/deployment-platform/enterprise-deployment/index.asp'>http://www.actuate.com/products/deployment-platform/enterprise-deployment/index.asp</a><br />
Rob0
- 108 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 120 Exstream
