Database Problems after Upgrade to 2.3
dfrenky
Hi, All.
For a while I've been running an embedded report engine (with Birt 2.2) without incident.
I'm using Tomcat 6 with a JNDI database connection specified in the web application's context.xml.
After upgrading to 2.3, Birt runs OK for a little while and then starts timing out on acquiring database connections. The only way to fix it is to restart Tomcat.
Apparently Birt isn't returning database connections to the connection pool. I do a runTask.close() after running the report. Is there any other way to force Birt to surrender its database connections?
Thanks for any assistance.
Here's some of the stack trace:
Aug 1, 2008 4:55:01 PM org.eclipse.birt.data.engine.odaconsumer.ConnectionManager openConnection
SEVERE: Cannot open connection.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, Communications link failure due to underlying exception:
** BEGIN NESTED EXCEPTION **
java.net.ConnectException
MESSAGE: Connection refused: connect
STACKTRACE:
java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl. ....
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doConnect(JDBCDriverManager.java:211)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getConnection(JDBCDriverManager.java:168)
at org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUrl(Connection.java:166)
at org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connection.java:123)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaConnection.open(OdaConnection.java:235)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:157)
at org.eclipse.birt.data.engine.executor.DataSource.newConnection(DataSource.java:210)
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSource.java:197)
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiDataSource(DataSourceRuntime.java:214)
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSource(QueryExecutor.java:280)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:224)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:508)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:189)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:177)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:143)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:470)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:114)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:79)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:248)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExecutor.executeQueries(ExtendedGenerateExecutor.java:211)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExecutor.execute(ExtendedGenerateExecutor.java:65)
at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor.execute(ExtendedItemExecutor.java:61)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:45)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:45)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:42)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:63)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:27)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:133)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:104)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:153)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:68)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:76)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:101)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:195)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:228)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:89)
There are no comments yet
