? is the installation of birt viewer in tomcat right??
i tried to installed birt viewer in apache tomcat and when i view the example it shows...
Title
Congratulations!
If you can see this report, it means that the BIRT viewer is installed correctly.
Sample Parameter:
my parameter
Aug 7, 2008 9:27 AM
Page:
does the sample report only contains myparameter???
thank you very much!
Title
Congratulations!
Sample Parameter:
my parameter
Aug 7, 2008 9:27 AM
Page:
Hi seisei,
Yes, when you do the initial install. The example is exactly that. As long as you see where it says, "If you can see this report, it means that the BIRT viewer is installed correctly", you've got it done correctly.Warning No formatter is installed for the format ipb0
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 145 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 900 Cloud Fax and Notifications
- 120 Exstream
