Each page of crosstab data is rendered as a separate excel sheet - Please help :(
Hello all,<br />
I have designed a crosstab report (plz chk attached file) in BIRT 2.5.1 using the CLASSIC MOTORS database. It has 2 columns- Product Name and Quantity ordered where product name is grouped together to show the sum of quantity in column 2. It is showing the expected results. The output is a multipage report. However when I view report as XLS<strong class='bbc'> (which is my requirement) </strong>then each page is shown on a <strong class='bbc'>different Excel Sheet.</strong>I have kept all default properties of the crosstab. <br />
Plz, please,please help me in this. <strong class='bbc'>I want all the pages in the same excel sheet</strong>. What properties of the cross tab should I change? or is this a bug in Birt??<br />
Thanks in advance,<br />
Kiran<br />
PS: Page 560 of the book "BIRT-Aa field guide to reporting, 2nd Edition" states that <br />
"<em class='bbc'>By contrast, an XLS report appears on a single Excel worksheet; page breaks<br />
that you specify in the report design have no effect."</em><br />
However still each page of the report is on a separate excel sheet. Plz plz help to show all data on just on excel sheet.
Kiran<br />
Hello Jason,<br />
Thanks for the quick reply. I am using the tribix xls emitter 2.5.1 (org.uguess.birt.report.engine.emitter.xls_2.5.1.201001221050.jar) which i downloaded from <a class='bbc_url' href='http://sourceforge.net/projects/tribix/'>Tribix - Extended Emitters for BIRT | Get Tribix - Extended Emitters for BIRT at SourceForge.net</a>. I am using them since my requirement is also to display charts in excel. <br />
Any other way to generate them in one excel sheet with Tribix emitters??<br />
Thanks in advance.<br />
Regards,<br />
Kiran0 -
I unzipped the birt-runtime-2_5_1 at another location and now the report is working fine .. thnx a lot..
fortunately there are 2 different types of reports - one with only charts and the other ones with data.
Thnx for ur prompt help.
Enjoy ur weekend.
Regards,
Kiran0 -
@kiranv increasing custom page height didn't solve my problem
0 -
In the property editor, go to "General" and change the "Layout Preference" to Auto Layout
0 -
Hi Eric, thanks for quick reply. The layout is auto only.
0 -
@Krunal Umak said:
Hi Eric, thanks for quick reply. The layout is auto only.I just looked at the attachments, and they are not Auto Layout. Be sure you change it and this should fix your issue.
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 145 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 120 Exstream
