setting gantt chart axis scale
davefromaldavefromal Junior Member
edited December 31, 1969 in Designing Analytics Reports
hi, i have a gantt chart with a datetime axis along the bottom. When I set the origin to MIN, it always has the origin 1 time unit earlier than the minimum data point. This means I always have a blank day at the start, which i can't have.
I've tinkered with setting axis scales:
function afterDataSetFilled( series, dataSet, icsc )
chart=icsc.getChartInstance();
xAxis = chart.getBaseAxes()[0];
yAxis = chart.getOrthogonalAxes( xAxis, true )[0];
xAxis1=chart.getOrthogonalAxes(xAxis,true)[0];
xScale=xAxis1.getScale();
v=DateTimeDataElementImpl.Create("3/3/2000");
xScale.setMin(v);
but I get errors about DateTimeDataElementImpl not being defined. This all seems so difficult, please help!
thanks
dave
  • davefromaldavefromal Junior Member
    ok to simplify the problem, can any show some code to set the axis origin of a chart datetime axis to the value of a report parameter?
    thanks!
  • mwilliamsmwilliams BIRT Guru
    Hi Dave,
    To use DateTimeDataElementImpl, you'll need to import the appropriate package:
    importPackage(Packages.org.eclipse.birt.chart.model.data.impl);
    Regards,
    Michael Williams
    eSignLive Evangelism & Community Manager | eSignLive by VASCO
    Find me on:
    Twitter
    Facebook
    Blog
    LinkedIn
    eSignLive Developer Community
    Email me:
    Google: [email protected]
    Dave,
    Try something like this:
    function beforeGeneration( chart, icsc )
    importPackage( Packages.org.eclipse.birt.chart.util);
    xScale=xAxis.getScale();
    xScale.setMin(DateTimeDataElementImpl.create(new CDateTime(2000,3,3,0,0)));
    Regards,
    Michael Williams
    Find me on:
    Twitter
    Facebook
    Blog
    LinkedIn
    Email me:
  • edited December 31, 1969
    Hello,
    I'm replying to this old thread because i have exactly the same problem as the author:
    The y axis of the gantt chart starts one time unit earlier than the min value.
    Is there a way to start exactly with the min value and keep auto scaling?
    Can you set up a simple example that shows your issue using the Classic Models, sample database and attach it in here for me to look at and test on? Thanks!
    Regards,
    Michael Williams
    Find me on:
    Twitter
    Facebook
    Blog
    LinkedIn
    Email me:
    I uploaded an example report here:
    http://www.birt-exchange.org/org/devshare/designing-birt-reports/1509-gantt-chart-auto-axis-scale-example/
    Try adding this code to your chart script:
    importPackage( Packages.org.eclipse.birt.chart.model.type.impl );
    function afterDataSetFilled(series, dataSet, icsc)
    ps = PluginSettings.instance( );
    dsp = ps.getDataSetProcessor( series.getClass() );
    //find min date
    if (series.getSeriesIdentifier() == "Series 1"){
    mmin = dsp.getMinimum( dataSet );
    mmax = dsp.getMaximum( dataSet );
    var yAxis = chart.getAxes().get(0).getAssociatedAxes().get(0);
    var yScale = yAxis.getScale();
    yScale.setMin(DateTimeDataElementImpl.create(mmin));
    yScale.setMax(DateTimeDataElementImpl.create(mmax));
    yAxis.setScale(yScale);
    Regards,
    Michael Williams
    Find me on:
    Twitter
    Facebook
    Blog
    LinkedIn
    Email me:
    //find min date
    That works like a charm.
    Thank you very much!
    You're welcome! Let us know whenever you have questions! :)
    Regards,
    Michael Williams
    Find me on:
    Twitter
    Facebook
    Blog
    LinkedIn
    Email me:
  • edited October 10, 2012
    Hello,
    How is the value "mmin" defined for both functions? The value "mmin" is not known by my beforeGeneration function.
    How can I define it as a global value for both functions in the script?
    //find min date
    Regards
    Gokhan
    It should work, as is, as long as your series is named "Series 1", which is the default. If you've change the series name, mmin will not get set, because the check for it being called "Series 1" will not be satisfied, and you'll get an error.
    Regards,
    Michael Williams
    Find me on:
    Twitter
    Facebook
    Blog
    LinkedIn
    Email me:
  • Hello ,
    I am trying to create same time of graph with custom columns on x axis trying to set date min and max and on y axis workitem count.
    markerLine.setValue(DateTimeDataElementImpl.create(new Date(y,m,d)));
    this line of code gives me below error.
    Cannot convert Invalid Date to java.lang.Long at line 34 of chart script: '
    Can you please suggest what is wrong, I tried using CDateTime method too.and imported all packages also.
