Questions about BIRT solution
Options
Hi,<br />
i'm using <strong class='bbc'>BIRT 2.6 plugin</strong> with <strong class='bbc'>Eclipse Helius</strong> in my RCP application to show analytic reports in PDF format. <br />
At this moment i need a View Part (Rich Client Platform ) to show a kind of Dashboard with most relevant information, my question is:<br />
Does BIRT have a solution for this ? Through some research i found terms like :<br />
> BIRT onDemand<br />
> Actuate 11<br />
> BIRT with Maximo<br />
> BIRT Dashboards<br />
> e.Reports<br />
> ....<br />
I'm a little confused by all this...is there any free solution to my question ? Thanks.<br />
P.S.- Sorry if the post is not in the correct topic
> BIRT onDemand<br />
> Actuate 11<br />
> e.Reports<br />
> ....<br />
Warning
No formatter is installed for the format ipb
Actuate BIRT 360 has a dashboarding feature to help create custom dashboards that can be drilled through to the actual reports, etc. One simple workaround you could do in the open source version would be to create a report that brings in the data from the different reports you want to "dashboard" and create a dashboard like report out of the data from the different reports and create drill through hyperlinks on each item to link to the actual report.
Dashboard Product Page:
http://www.birt-exchange.com/be/products/birt-user-experience/dashboards/features/Warning No formatter is installed for the format ipb0
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 145 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 900 Cloud Fax and Notifications
- 120 Exstream
