Report as body of email
I would like to have the option to send reports as the body of an e-mail. There is example on devshare <a class='bbc_url' href='http://www.birt-exchange.org/org/devshare/deploying-birt-reports/991-mailing-birt-reports-as-body-of-email/'>here</a> that purports to do just that, but I don't know how to use it. Can anyone point me in the right direction?
In that example, they use Actuate 10. I'm not sure I'm understanding the post correctly, but it says that if you don't have A10, then the mail and activation jars need to be added to your java project. From there, it appears you just call the MailSend class and it creates an email and calls the runandrender task to run the report. I have not set this up or tested with it at all. Just get this from looking at the included java files.Warning No formatter is installed for the format ipb0
<p>Here is the updated DevShare link:</p>
<p><a data-ipb='nomediaparse' href='http://developer.actuate.com/community/forum/index.php?/files/file/482-mailing-birt-reports-as-body-of-email/'>http://developer.actuate.com/community/forum/index.php?/files/file/482-mailing-birt-reports-as-body-of-email/</a></p>
<p>Hi Clement,</p>
<p> </p>
<p>Thank you for responding, I have tried this. I am getting the below error. Do you have any idea what might be causing this?</p>
<p> </p>
<div>javax.mail.SendFailedException: Invalid Addresses;</div>
<div> nested exception is:</div>
<div>com.sun.mail.smtp.SMTPAddressFailedException: 554 5.7.1 <birt@xxxx.com>: Relay access denied</div>
<div> </div>
<div>at com.sun.mail.smtp.SMTPTransport.rcptTo(SMTPTransport.java:1446)</div>
<div>at com.sun.mail.smtp.SMTPTransport.sendMessage(SMTPTransport.java:736)</div>
<div>at javax.mail.Transport.send0(Transport.java:191)</div>
<div>at javax.mail.Transport.send(Transport.java:120)</div>
<div>at SendEmail.main(SendEmail.java:54)</div>
<div>Caused by: com.sun.mail.smtp.SMTPAddressFailedException: 554 5.7.1 <birt@xxxx.com>: Relay access denied</div>
<div> </div>
<div>at com.sun.mail.smtp.SMTPTransport.rcptTo(SMTPTransport.java:1344)</div>
<div>... 4 more</div>Warning No formatter is installed for the format ipb0 -
<p>Are you able to send an email in the shell using the same user who ran this report? You may need to work with your System Admin / Mail Administrator regarding this error.</p>Warning No formatter is installed for the format ipb0
@Clement Wong said:
Here is the updated DevShare link:Hi Clement,
Would you be able to share the latest devshare link as I am not able to a
0 -
This should be the replacement link:
https://forums.opentext.com/forums/discussion/60896/mailing-birt-reports-as-body-of-emailWarning No formatter is installed for the format ipb0
- 107 Developer Announcements
- 53 Articles
- 104 General Questions
- 141 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 76 Digital Asset Management
- 118 Exstream
