How to add data cells to group header?
I currently have a report where users can choose up to 10 columns to be displayed in a table.
I am using the following code to dynamically insert the columns and data into the detail row of the table.
var mytable = reportContext.getDesignHandle().findElement("MainTable");
for (j=1; j<10;j++) {
if (params["column_"+j]!="blank") {
//second parameter is before(-1) or after(1)
mytable.insertColumn(j,1);
//get first detail row
mydetail = mytable.getDetail().get(0);
//get first column and add detail data item
var tcell = mydetail.getCells( ).get( j );
var mydata = elementFactory.newDataItem( null );
mydata.setResultSetColumn( params["column_"+j].value);
tcell.getContent( ).add( mydata );
//get header and add label
var myheader = mytable.getHeader( ).get( 0 );
tcell = myheader.getCells( ).get( j );
var mylabel = elementFactory.newLabel( null );
mylabel.setText( params["column_"+j].displayText );//$NON-NLS-1$
tcell.getContent( ).add( mylabel );
This is working fine but I have now been asked to re-create the report so that the data is not but in the detail but into the 'lowest' of 4 possible groups that might have been setup.
So my question is how would i need to alter this code to insert the data cells into the groupheader row and not into the detail row of the table.
Thanks in advance.
Thanks in advance.
managed to find a solution after digging around in this forum. Found a post on deleting cells from group header so re-used that code.
Added the following to my code to determine at which 'level' in the table the data cells should be inserted:
if (params["data_level"] =="Group1")
{mydetail = mytable.getGroups().get(0).getHeader().get(0);}
else if (params["data_level"] =="Group2")
{mydetail = mytable.getGroups().get(1).getHeader().get(0);}
else if (params["data_level"] =="Group3")
{mydetail = mytable.getGroups().get(2).getHeader().get(0);}
else if (params["data_level"] =="Group4")
{mydetail = mytable.getGroups().get(3).getHeader().get(0);}
else {mydetail = mytable.getDetail().get(0);}0
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 144 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 120 Exstream
