Works in 4.2.1 but not in 4.2.2
Options
I have report that runs fine in 4.2.1 (freeware) but not in 4.2.2 I have recreated the report using the example data base and still seeing the same issue. Could someone check if I have an error in logic, that was OK in 4.2.1 or if this is new bug in 4.2.2?
I have attached the report and a screen shot, Sum of Named States is 49 in 4.2.1 but is 122 in 4.2.2 the correct answer is 49
I wrote it in 4.2.1 Copy and paste to a new folder and open and run with 4.2.2 My production report is opening with Apache and seeing the same results. We are running the 64 bit 4.2.2 in production, and I download a fresh 32 bit version on Friday to test on my desktop PC. Same results all around.
I am using this filter which I believe is the part that is misbehaving in 4.2.2
row["STATE"] !== 'Empty'
Warning
No formatter is installed for the format ipb
Hi Jenkins,
you should use != for not equals instead of !==
There seems to be a bug in 4.2.2. I ve seen that you have replaced STATE with Empty if the dataset value is null:
row["STATE"] --> if(datasetRow["STATE"]!=null) ... else "Empty"
The aggregation has a filter on row["STATE"] that doesn't work. I replaced the filter with row["STATE"]!=null and it worked. I m assuming that there is a bug in 4.2.2 that keeps using the original dataset value instead of the row value.0 -
cbrell,<br />
Thanks for the JavaScript suggestion "!= for not equals instead of !==", I took your suggestion. <br />
<em class='bbc'>Of Note to anyone reading this post; changing the filter to row["STATE"] != 'Empty' DOES NOT correct the problem.</em><br />
Thank for the work around also. I removed the changing of Null > Empty and used row["STATE"]!=null, for my production fix. Seems to be working fine.<br />
I will post a Bugzilla and enter the ticket number here.<br />
<strong class='bbc'>Edit:</strong><br />
Bug 403656 <br />
<a class='bbc_url' href='https://bugs.eclipse.org/bugs/show_bug.cgi?id=403656'>https://bugs.eclipse.org/bugs/show_bug.cgi?id=403656</a>Warning No formatter is installed for the format ipb0
- 108 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 120 Exstream
