Problem with Excel emitters in BIRT runtime 4.3.1
dwbrock
<p>I have an Excel report which works fine from within the report designer when using the "View as (XLS, XLS_SPUDSOFT, or XLSX)" options. However when I run any of these emitters from Java using the BIRT runtime I get the following error:</p><p> </p><p>May 5, 2014 12:01:44 PM uk.co.spudsoft.birt.emitters.excel.framework.Logger info
INFO: start:org.eclipse.birt.report.engine.content.impl.ReportContent@862fb35
May 5, 2014 12:01:47 PM org.eclipse.birt.report.engine.api.impl.EngineTask handleFatalExceptions
SEVERE: An error happened while running the report. Cause:
java.lang.ArrayIndexOutOfBoundsException: 0
at sun.font.ExtendedTextSourceLabel.createCharinfo(Unknown Source)
at sun.font.ExtendedTextSourceLabel.getCharinfo(Unknown Source)
at sun.font.ExtendedTextSourceLabel.getLineBreakIndex(Unknown Source)
at java.awt.font.TextMeasurer.calcLineBreak(Unknown Source)
at java.awt.font.TextMeasurer.getLineBreakIndex(Unknown Source)
at java.awt.font.LineBreakMeasurer.nextOffset(Unknown Source)
at java.awt.font.LineBreakMeasurer.nextLayout(Unknown Source)
at uk.co.spudsoft.birt.emitters.excel.StyleManagerUtils.calculateTextHeightPoints(StyleManagerUtils.java:774)
at uk.co.spudsoft.birt.emitters.excel.handlers.CellContentHandler.endCellContent(CellContentHandler.java:238)
at uk.co.spudsoft.birt.emitters.excel.handlers.AbstractRealTableCellHandler.interruptCell(AbstractRealTableCellH
andler.java:136)
at uk.co.spudsoft.birt.emitters.excel.handlers.AbstractRealTableCellHandler.endCell(AbstractRealTableCellHandler
.java:89)
at uk.co.spudsoft.birt.emitters.excel.ExcelEmitter.endCell(ExcelEmitter.java:337)
at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.endCell(CompositeContentEmitter.java:146)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEmitter.flushRow(HTMLTableLayoutEmitter.java:351)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEmitter.flush(HTMLTableLayoutEmitter.java:315)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEmitter.endRow(HTMLTableLayoutEmitter.java:642)
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.endContent(ContentEmitterUtil.java:111)
at org.eclipse.birt.report.engine.layout.html.buffer.AbstractNode.end(AbstractNode.java:69)
at org.eclipse.birt.report.engine.layout.html.buffer.HTMLPageBuffer.endRow(HTMLPageBuffer.java:199)
at org.eclipse.birt.report.engine.layout.html.buffer.HTMLPageBuffer.endContainer(HTMLPageBuffer.java:140)
at org.eclipse.birt.report.engine.layout.html.buffer.TableBreakBuffer.endContainer(TableBreakBuffer.java:360)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.end(HTMLStackingLM.java:42)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:141)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.layoutChildren(HTMLTableBandLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLRepeatHeaderLM.layoutChildren(HTMLRepeatHeaderLM.java:46)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:181)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at com.mentor.mcd.xdm.xdmreport.XDMReportEngine.run(XDMReportEngine.java:145)
at com.mentor.mcd.xdm.xdmreport.XDMReportCommandLine.start(XDMReportCommandLine.java:17)
at com.mentor.mcd.xdm.xdmreport.XDMReportApp.main(XDMReportApp.java:80)
Error: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2363)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:191)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
andler.java:136)
.java:89)
... 4 more</p>
dwbrock
<p>OK, so I found that if I ran the Java program under JRE6 then I get the error. However if I run under JRE7 then the report runs fine. I currently have a requirement that the Java application run under JRE6 - any suggestions about how I can work around this?</p><p> </p><p> </p>
rveeraraghav
<p>I ran into a similar issue when I integrated spudsoft code into my project ( with Birt 3.7.2) The problem was with static integers used in spudsoft code.. What happened in my case was, the value during compile and runtime didn't match. The solution was to recompile spudsoft code so the compiler made use of the same environment which was there in runtime and resolved the statics properly to make it go away. Do you think you have such an issue? See if you can include these plugins and debug them.</p><p>Good luck.</p>
