Problem when calling BIRT file in java as standalone
  I am new to this BIRT Report.I created BIRT Report(firstReport..rptdesign)
using Eclipse.I needed to call this report file from java as standalone.So i created below java code and run(Runas -> Java application).When i run this java class i m getting error " org.osgi.framework.BundleException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle org.eclipse.osgi.".Is there any configuration issue?i have added all jars required for BIRT into my classpath.So any one can help me out this issue?
JAVA Code
package TestBirt;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLCompleteImageHandler;
import org.eclipse.birt.report.engine.api.HTMLEmitterConfig;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.ReportEngine;
public class TestBirtAPI {
 static void executeReport() throws EngineException
  Map parameters = new HashMap();
        parameters.put("PARAM1", "1234");
        EngineConfig config = null;
        try
         String format = HTMLRenderOption.OUTPUT_FORMAT_PDF;
         config = new EngineConfig();
                config.setEngineHome("C:\\birt-runtime-4_2_0\\birt-runtime-4_2_0\\ReportEngine");
            HTMLEmitterConfig hc = new HTMLEmitterConfig( );
            HTMLCompleteImageHandler imageHandler = new HTMLCompleteImageHandler( );
            hc.setImageHandler( imageHandler );
            config.setEmitterConfiguration( HTMLRenderOption.OUTPUT_FORMAT_HTML, hc );
            Platform.startup(config);
            ReportEngine engine = new ReportEngine( config );
            IReportRunnable report = null;
            String reportFilepath = "D:/BIRT_WS/test_Birt/firstReport.rptdesign";
            try{
             report = engine.openReportDesign(reportFilepath);
            catch(Exception e)
             System.err.println( "Report " + reportFilepath + " not found!\n" );
                engine.destroy( );
                return;
            IRunAndRenderTask task = engine.createRunAndRenderTask( report );
            HTMLRenderOption options = new HTMLRenderOption( );
            options.setOutputFormat(format);
            options.setOutputFileName( "D:/BIRT_WS/test_Birt/REPORT.pdf" );
            task.setRenderOption( options );
            task.setParameterValues(parameters);
            try {
                task.run( );
            catch ( EngineException e1 ) {
                System.err.println( "Report " + reportFilepath + " run failed.\n" );
                System.err.println( e1.toString( ) );
            engine.destroy( );
            return;
        catch (Exception e)
         e.printStackTrace();
  * @param args
 public static void main(String[] args) {
  // TODO Auto-generated method stub
    try
     executeReport();
    catch(Exception e)
  • You're using code from very old versions. Try this:
    package TestBirt;
    import org.eclipse.birt.report.engine.api.PDFRenderOption;
    Map<String, String> parameters = new HashMap<String, String>();
            IReportEngine engine = null;
            try
             config.setLogConfig("/logs", java.util.logging.Level.WARNING);
             IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
             engine = factory.createReportEngine( config );
             try{
             catch(Exception e)
                 engine.destroy( );
                    return;
             PDFRenderOption options = new PDFRenderOption( );
             options.setOutputFormat("pdf");
             try {
                 task.run( );
               engine.destroy( );
               return;
          catch (Exception e)
      * @param args
        try
         executeReport();
        catch(Exception e)
    Regards,
    Michael Williams
    eSignLive Evangelism & Community Manager | eSignLive by VASCO
    Find me on:
    Twitter
    Facebook
    Blog
    LinkedIn
    eSignLive Developer Community
    Email me:
    Google: [email protected]
  • Hello
    i used your code to creating a report using eclipse(mars) birt designer
    but i have a error:
    Exception in thread "main" java.lang.NoSuchMethodError: org.eclipse.birt.report.engine.api.EngineConfig.getLogRollingSize()I
    at org.eclipse.birt.report.engine.api.impl.ReportEngine.intializeLogger(ReportEngine.java:222)
    at org.eclipse.birt.report.engine.api.impl.ReportEngine.<init>(ReportEngine.java:136)
    at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$1.run(ReportEngineFactory.java:18)
    at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$1.run(ReportEngineFactory.java:1)
    at java.security.AccessController.doPrivileged(Native Method)
    at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory.createReportEngine(ReportEngineFactory.java:14)
    at org.eclipse.birt.report.engine.api.ReportEngine.<init>(ReportEngine.java:71)
    at test.main(test.java:30)
    my java(jdk) is 1.8
    i can not find the problem, can you help me please?
  • How to Provide the Relative Path of design to Report Engine.
    >>String reportFilepath = "./Webapp/firstReport.rptdesign";
