Merging cells vertically on group
Hi team,
I am facing the following issue with a report design on BIRT for MAXIMO 7.5:
I have my report grouped by one field and moved the rest of the fields I need to be merged vertically into that row. Also in the grouped row I have an aggregation to sum up the values beneath it
You can see the attached files with the needed output and the current output so far.
I need to move either the unmerged cells into the group row without loosing the data, or to moved the values in the group row into the details row, but merged them vertically.
The design file is attached also if it helps in any way. I am using Script data set.
I searched for this subject, and could not find anything.
Any help is appreciated, and thank you all for your time.
Regards.
