After succesfull installation Ihub won't start
<p>Hi all,</p>
<p> </p>
<p>I have been struggling to setup Ihub over the last few weeks. However after adjusting the <span style="color:rgb(0,136,0);">kernel'</span><span>s SHMMAX parameter the installation went smooth. </span></p>
<p> </p>
<p><span>However when I go to <a data-ipb='nomediaparse' href='http://myipaddress:8700/iportal'>http://myipaddress:8700/iportal</a>nothing show's up. </span></p>
<p>I checked:</p>
<p> </p>
<p>- port 8700 is open on server<br>
- firewall on my local machine allows traffic from and to 8700</p>
<p>- I can start and stop PostgreSQL</p>
<p>- I can start Ihub via ./startiHub.sh</p>
<p> </p>
<p>However if I try to stip Ihub via stopiHub.sh the console tells me that the Ihub process is not running. Additionally my System Administrator also checked port 8700 but no processes seem top be running after I start the Ihub. I have included the output from my console below:</p>
<p> </p>
<p><strong>Start Ihub</strong></p>
<p> </p>
<div>[britactuate@srv4a BIRTiHub]$ ./startiHub.sh</div>
<div>The AC_JRE_HOME property is set to be /home/britactuate/BIRTiHubFType/java</div>
<div>Path to iHub is /home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub</div>
<div>Path to Java Runtime Kit is /home/britactuate/BIRTiHubFType/java</div>
<div>Starting PostgreSQL for Actuate ...</div>
<div>Starting Actuate BIRT iHub 3 ...</div>
<div>Calling CheckJavaVersion to validate required java version</div>
<div>Checking java version: Required minimum java version is 1.6.0</div>
<div>Checking java version: Current java version is 1.8.0_25, 64-bit</div>
<div>Checking java version: 1.8.0_25 is okay to run BIRT iHub.</div>
<div>Start iHub complete.</div>
<div>nohup: redirecting stderr to stdout</div>
<div>setup complete.</div>
<div> </div>
<div><strong>Stop Ihub</strong></div>
<div> </div>
<div>
<div>./stopiHub.sh</div>
<div> iHub process id = 15781</div>
<div> </div>
<div> iHub shutting down in 120 seconds...</div>
<div> </div>
<div> </div>
<div> Are you sure you want to shut down the iHub now? [yes] yes</div>
<div> </div>
<div> iHub shutting down now...</div>
<div> </div>
<div> iHub process is not running.</div>
<div> </div>
<div> </div>
<div> Waiting for iHub to shut down.</div>
<div> </div>
<div> iHub SHUTDOWN IS COMPLETE</div>
<div> </div>
<div> Actuate PostgreSQL seem to be running. Trying to stop Actuate PostgreSQL.</div>
<div> Please wait...</div>
<div> </div>
<div>Starting stoppostgresql at Mon 06/01/2015 06:50:43</div>
<div> </div>
<div>AC_SERVER_HOME=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub</div>
<div>Completed stoppostgresql</div>
<div> </div>
<div> Failed to stop the Actuate PostgreSQL for the uninstall purpose</div>
<div> Exiting the uninstall process.</div>
<div> </div>
</div>
<p> </p>
<p>Any suggestions would be appreciated.</p>
<p> </p>
<p>Kind regards,</p>
<p> </p>
<p>Michel</p>
<p> </p>
<p> </p>
<p>I checked:</p>
<p> </p>
<p> </p>
<p> </p>
<p> </p>
<div> </div>
<div> </div>
<div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
</div>
<p> </p>
<p> </p>
<p> </p>
<p>Michel</p>
<p>The process "ihubservletcontainer" is the front end process for iPortal that should be listening on port 8700.</p>
<p> </p>
<p>When you start the iHub do you see this process running?</p>
<p> </p>
<p>Can you attach the log files from your iHub for analysis?</p>
<p>They should be located in the directory "./ihub/data/server/log".</p>
<p> </p>
<p>The 4 log files I would be most interested in for this issue are the ihub, ihubd, ihubc, and ihubservletcontainer.</p>
<p>Hi Jesse,</p>
<p> </p>
<p>there is no process running on port 8700 after i start Ihub. </p>
<p>I have attached two dirs with log files.One dir before I cleaned up the log file dir. Than I stopped I hub, deleted all log files and restarted. the result logfiles are in the second dir. </p>
<p> </p>
<p>However none of the files you mention are in de log dir.</p>
<p> </p>
<p>regards,</p>
<p>Michel</p>
<p> </p>
0 -
<p>Alright, looks like the iHub is failing during start up due to a port conflict:</p>
<p> </p>
<blockquote class="ipsBlockquote">
<p> </p>
<p>****3062081280*pmdfacade.cpp*02562*08000*2015JUN01*11:05:10</p>
<div> Caught ServerException with Error Number : 9004</div>
<div> Localized String : SOAP endpoint start failure : The specified port is in use.</div>
<div> Parameter: 8100</div>
</blockquote>
<p> </p>
<p>Can you check for another process on your system using port 8100?</p>
<p>Hi Jesse,</p>
<p> </p>
<p>I have had my System Administrator stop the process on 8100 which by the way was occupied by an ihub process. It seems that the process is not killed after stopping ihub via ./stopiHub<br>
I deleted my logfiles and restarted Ihub with the 8100 being killed.<br>
This resulted in a new logfile with errors (eg message port 8100 is gne, but software still does not start. I have included the new logfile. perhaps you can take a look and point me in the right direction. It looks like it has someting to do with the processor of the server. Please note I am running the software on a VPS 5virtual server)<br><br>
kind regards,<br><br>
Michel</p>
0 -
<p>cannot upload the file. Therefore please find below the output:</p>
<p> </p>
<div>Directory : /home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/data/server/log</div>
<div> File : /home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/data/server/log</div>
<div> Level : 8000</div>
<div> Host : srv4a.zcore.nl</div>
<div> ID : </div>
<div> Physical Memory : 4096 MB</div>
<div> Platform : Linux</div>
<div> OS Version : 2.6.32-042stab108.2</div>
<div> System : 6</div>
<div> System Bound : 6</div>
<div> System Logical : 6</div>
<div> System Threads : 1</div>
<div> Vendor : GenuineIntel</div>
<div> Vendor description : Intel(R) Xeon(R) CPU E5645 @ 2.40GHz</div>
<div> CPU clock speed : 1466</div>
<div> Actuate file version : XxXxXDevelopment BuildXxXxXxXxXxXxX</div>
<div> Actuate product version : BIRT iHub 3.1</div>
<div> Actuate file build number : XxXBuild NumberXxX</div>
<div> Actuate product build number : 231A150206</div>
<div>Processor Thread Status : HyperThreading Technology may be supported </div>
<div> but not enabled or HyperThreading Technology not supported </div>
<div> ulimit CPU time : -1 (seconds)</div>
<div> file size : 4194303 KB</div>
<div> data size : 4194303 KB</div>
<div> stack size : 10240 KB</div>
<div> memory size : 4194303 KB</div>
<div> coredump size : 0 KB</div>
<div> file descriptors : 1024</div>
<div> </div>
<div> Environment variables : </div>
<div> AC_JRE_HOME=/home/britactuate/BIRTiHubFType/java</div>
<div> XDG_SESSION_ID=c6008</div>
<div> AC_ODBC_HOME=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/odbc</div>
<div> HOSTNAME=srv4a.zcore.nl</div>
<div> SHELL=/bin/bash</div>
<div> TERM=xterm</div>
<div> HISTSIZE=1000</div>
<div> ODBCINST=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/odbc/odbcinst.ini</div>
<div> SSH_CLIENT=109.89.185.32 50377 22</div>
<div> AC_SERVER_HOME=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub</div>
<div> AC_SYSTEM_NAME=srv4a</div>
<div> AC_SHARED_HOME=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/shared</div>
<div> setupmode=1</div>
<div> SSH_TTY=/dev/pts/0</div>
<div> AC_IHUB_BASE_HOME=/home/britactuate/BIRTiHubFType/modules/BIRTiHub</div>
<div> AC_MACHINE_NAME=srv4a</div>
<div> JRE_HOME=/home/britactuate/BIRTiHubFType/java</div>
<div> USER=britactuate</div>
<div> LD_LIBRARY_PATH=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/lib:/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/odbc/lib:/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/odbc/lib:/usr/lib:/lib/i386/server:</div>
<div> LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=01;36:*.au=01;36:*.flac=01;36:*.mid=01;36:*.midi=01;36:*.mka=01;36:*.mp3=01;36:*.mpc=01;36:*.ogg=01;36:*.ra=01;36:*.wav=01;36:*.axa=01;36:*.oga=01;36:*.spx=01;36:*.xspf=01;36:</div>
<div> AC_DATA_HOME=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/data</div>
<div> ODBC_LIB_PATH=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/odbc/lib</div>
<div> AC_SETUP_VOLUME_NAME=Default Volume</div>
<div> AC_LIBPATH64=/usr/lib64:/home/britactuate/BIRTiHubFType/java/lib/amd64</div>
<div> AC_SYSTEM_SCHEMA_NAME=srv4a_zcore_nl</div>
<div> AC_CONFIG_HOME=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/shared/config</div>
<div> PATH=/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/britactuate/.local/bin:/home/britactuate/bin</div>
<div> MAIL=/var/spool/mail/britactuate</div>
<div> PWD=/home/britactuate/BIRTiHubFType/modules/BIRTiHub</div>
<div> INTSRVR_JRE_HOME=</div>
<div> AC_JRE32_HOME=${AC_JRE32_HOME}</div>
<div> HISTCONTROL=ignoredups</div>
<div> HOME=/home/britactuate</div>
<div> SHLVL=2</div>
<div> ODBCINI=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/odbc/odbc.ini</div>
<div> AC_SOAP_DISPATCH_ADDRESS=</div>
<div> LOGNAME=britactuate</div>
<div> AC_TEMPLATE_NAME=small</div>
<div> SSH_CONNECTION=109.89.185.32 50377 109.70.3.46 22</div>
<div> LESSOPEN=||/usr/bin/lesspipe.sh %s</div>
<div> XDG_RUNTIME_DIR=/run/user/1002</div>
<div> ODBC_MGR_PATH=/home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/odbc/lib</div>
<div> _=/usr/bin/nohup</div>
<div> AC_SERVER_NAME=srv4a.zcore.nl</div>
<div> AC_JRE64_HOME=</div>
<div> AC_JAVA_HOME=#AC_JAVA_HOME#</div>
<div> AC_SERVER_IP_ADDRESS=srv4a.zcore.nl</div>
<div> AC_DOC_BASE=</div>
<div> JAVA_HOME=/home/britactuate/BIRTiHubFType/java</div>
<div> </div>
<div>
System Header Information
</div>
<div> </div>
<div>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</div>
<div>****3062241024*licensekey.cpp*01183*PRGRM*2015JUN02*10:41:52</div>
<div> ===================== LICENSE INFORMATION ================================</div>
<div> License Id : 4</div>
<div> Mode : Enterprise</div>
<div> Is Development iHub server: false</div>
<div> System CPU Core Limit : Unlimited</div>
<div> Expiration Date : 02/05/2018</div>
<div> Trial Period : Unlimited</div>
<div> Is License Node Locked : false</div>
<div> Usage Type : BIRT iHub FType</div>
<div> Options Enabled:</div>
<div>
</div>
<div> MultiApp (0 users)</div>
<div> BIRTReport (Unlimited users)</div>
<div> BIRTInteractiveViewer (Unlimited users)</div>
<div> ReportStudio (Unlimited users)</div>
<div> BIRTPageSecure (0 users)</div>
<div> Dashboards (Unlimited users)</div>
<div> InteractiveCrosstabs (Unlimited users)</div>
<div> eReportDataConnector (0 users)</div>
<div> AccessiblePDF (0 users)</div>
<div> </div>
<div> Options Not Enabled : AddVolume </div>
<div> ==========================================================================</div>
<div>****3062241024*srvrinit.cpp*00037*PRGRM*2015JUN02*10:41:52</div>
<div> Could not delete PID file: /home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/etc/ihubd.pid</div>
<div>****3062241024*acsoapendpoint.cpp*00365*PRGRM*2015JUN02*10:41:52</div>
<div> Thread pool enable: 0</div>
<div> Max thread: 50</div>
<div> Thread pool idle timeout: 300</div>
<div> SslEngineEnabled: 1</div>
<div> Ssl ServerCertFile: /home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/shared/config/credentials/birtihub_nopassphrase.pem</div>
<div> Ssl RootCertFile: /home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/shared/config/credentials/birtihub_nopassphrase.pem</div>
<div> Ssl RootCertPath: </div>
<div> Ssl ServerKeyFile: /home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/shared/config/credentials/birtihub_nopassphrase.pem</div>
<div> SslCipherSuites: ALL:!ADH:!EDH</div>
<div>****3062241024*acsoapendpoint.cpp*00401*PRGRM*2015JUN02*10:41:52</div>
<div> Finished StartSoapEndPointMainLoop...</div>
<div>****3062241024*pmdfacade.cpp*02562*08000*2015JUN02*10:41:52</div>
<div> Created external soapendpoint at port : 8100</div>
<div>****3054168896*acsoapendpoint.cpp*00594*08000*2015JUN02*10:41:52</div>
<div> SoapEndPoint: Enter StartSoapEndPointMainLoop...</div>
<div> </div>
<div>****3062241024*acsoapendpoint.cpp*00667*PRGRM*2015JUN02*10:41:52</div>
<div> StartTCPSSLListen:</div>
<div> **getServerKeyFile: /home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/shared/config/credentials/birtihub_nopassphrase.pem</div>
<div> getServerCertFile: /home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/shared/config/credentials/birtihub_nopassphrase.pem</div>
<div> getRootCertFile: /home/britactuate/BIRTiHubFType/modules/BIRTiHub/iHub/shared/config/credentials/birtihub_nopassphrase.pem</div>
<div> getRootCertPath: </div>
<div> getSslCipherSuites: ALL:!ADH:!EDH</div>
<div>****3062241024*acsoapendpoint.cpp*00401*PRGRM*2015JUN02*10:41:53</div>
<div>****3062241024*pmdfacade.cpp*02562*08000*2015JUN02*10:41:53</div>
<div> Created external SSL soapendpoint at port : 8101</div>
<div>****3041917760*acsoapendpoint.cpp*00594*08000*2015JUN02*10:41:53</div>
<div> </div>
<div>****3062241024*acsoapendpoint.cpp*00365*PRGRM*2015JUN02*10:41:53</div>
<div> Created internal soapendpoint at port : 13100</div>
<div>****3062241024*adminlicense.cpp*01413*08000*2015JUN02*10:41:53</div>
<div> Failed to find activation file.</div>
<div> Activation code checking not passed, cannot start any service...</div>
<div>****3029334848*acsoapendpoint.cpp*00594*08000*2015JUN02*10:41:53</div>
<div> </div>
<div> PMD Startup Completed.</div>
<div> Blocked for receiving messages. </div>
<div>****3016751936*pmdfacade.cpp*02562*08000*2015JUN02*10:42:03</div>
<div> </div>
<div> Cannot Get Process Affinity mask...</div>
<div> </div>
<div> Process Affinity violation detected on ihubservletcontainer</div>
<div>****3016751936*pmdfacade.cpp*02562*08000*2015JUN02*10:42:13</div>
<div> The Following Process recorded as crashed: ihubservletcontainer</div>
<div>****3016751936*csmgr.cpp*00229*08000*2015JUN02*10:42:13</div>
<div> AcRunningProcess::Dump</div>
<div> Server Name : ihubservletcontainer</div>
<div> Server Pid : 28877</div>
<div> State Desc : </div>
<div> Error Code : 0</div>
<div> proc State : 1</div>
<div> Restart Cnt : 0</div>
<div> IsMain Proc : 0</div>
<div> Soap Port : 0</div>
<div> Soap IP addr : </div>
<div> </div>
<div> </div>
<div>****3016751936*pmdfacade.cpp*02562*08000*2015JUN02*10:42:23</div>
<div>****3016751936*csmgr.cpp*00229*08000*2015JUN02*10:42:23</div>
<div> Server Pid : 28886</div>
<div> Restart Cnt : 1</div>
<div> </div>
<div> </div>
<div>****3016751936*pmdfacade.cpp*02562*08000*2015JUN02*10:42:33</div>
<div>****3016751936*csmgr.cpp*00229*08000*2015JUN02*10:42:33</div>
<div> Server Pid : 28888</div>
<div> Restart Cnt : 2</div>
<div> </div>
<div> </div>
<div>****3016751936*pmdfacade.cpp*02562*08000*2015JUN02*10:42:43</div>
<div>****3016751936*csmgr.cpp*00229*08000*2015JUN02*10:42:43</div>
<div> Server Pid : 28891</div>
<div> Restart Cnt : 3</div>
<div>****2995772224*adminlicense.cpp*01413*08000*2015JUN02*10:42:53</div>
<div>****2968517440*pmdfacade.cpp*02562*08000*2015JUN02*10:42:53</div>
<div> Begin to shutdown the following service: Platform</div>
<div>****2934954816*pmdfacade.cpp*02562*08000*2015JUN02*10:42:53</div>
<div> Begin to shutdown the following service: Monitor</div>
<div>****2955934528*pmdfacade.cpp*02562*08000*2015JUN02*10:42:53</div>
<div> Begin to shutdown the following service: BIRT</div>
<div>****2924464960*pmdfacade.cpp*02562*08000*2015JUN02*10:42:53</div>
<div> Begin to shutdown the following service: Agent</div>
<div>****2945444672*pmdfacade.cpp*02562*08000*2015JUN02*10:42:53</div>
<div> Begin to shutdown the following service: RESTServer</div>
<div>****2995772224*adminlicense.cpp*01413*08000*2015JUN02*10:43:53</div>
<div>****2968517440*pmdfacade.cpp*02562*08000*2015JUN02*10:43:53</div>
<div>****2934954816*pmdfacade.cpp*02562*08000*2015JUN02*10:43:53</div>
<div>****2955934528*pmdfacade.cpp*02562*08000*2015JUN02*10:43:53</div>
<div>****2924464960*pmdfacade.cpp*02562*08000*2015JUN02*10:43:53</div>
<div>****2945444672*pmdfacade.cpp*02562*08000*2015JUN02*10:43:53</div>
0 -
<p>Yeah, it looks to be having issues determining the process affinity mask:</p>
<p> </p>
<p> </p>
<p><span style="color:rgb(40,40,40);font-family:'Source Sans Pro', sans-serif;"> Cannot Get Process Affinity mask...</span></p>
<div style="margin:0px;color:rgb(40,40,40);font-family:'Source Sans Pro', sans-serif;">****3016751936*pmdfacade.cpp*02562*08000*2015JUN02*10:42:23</div>
<div style="margin:0px;color:rgb(40,40,40);font-family:'Source Sans Pro', sans-serif;"> </div>
<div style="margin:0px;color:rgb(40,40,40);font-family:'Source Sans Pro', sans-serif;"> Process Affinity violation detected on ihubservletcontainer</div>
<div style="margin:0px;color:rgb(40,40,40);font-family:'Source Sans Pro', sans-serif;">****3016751936*pmdfacade.cpp*02562*08000*2015JUN02*10:42:33</div>
</blockquote>
<p> </p>
<p>This may have to do with your VPS CPU configuration.</p>
<p>Is is possible to provide your current CPU configuration?</p>
<p>Hi Jesse,</p>
<p> </p>
<p>I have had a long session with my system administrator to see wether we could get the programm to run by changing the binding of the cpu's. However no luck. He suggested to move from a VPS to a dedicated server which I did. On the dedicated server installation went smoothly so I have the program up and running. </p>
<p> </p>
<p>Perhaps it is advisable to other users not to install Ihub on a VPS but use a dedicated server with it's own cpu's.</p>
<p> </p>
<p>As for now I have some questions related to embedding reports in webpages via JSAPI but I will open a new thread for that.</p>
<p> </p>
<p>Thanx again for your support,</p>
<p> </p>
<p>regards,</p>
<p> </p>
<p>Michel</p>
0 -
<p>Thank you for the update and details.</p>
<p>I am glad to hear you got it working on a dedicated server.</p>
<p> </p>
<p>I know of several instances of users with iHub on instances of AWS as well as other virtual instances.</p>
<p>There may be something more specific to your environments configuration that is causing the issue.</p>
<p> </p>
<p>If you have the availability, I would like to see about getting a support case setup to collect more information from you about the startup issue while installed on your VPS instance so at the very least we can get a bug report submitted for the issue.</p>
<p>Hi Jesse,</p>
<p> </p>
<p>I am happy to share the config of the vps.To my understanding talking to my system administrator it was not possible to bind processes to the cpu's due to the fact they are shared cpu's in the vps environment. if you let me know exactly what you need I can give you the details. As for now I will concentrate on getting my reports published correctly in my webpages. As mentioned in my new thread I am struggeling with the resonsiveness of the JSAPI frame. If you have time I am anxious to know if there is a way to make the frame responsive.</p>
<p> </p>
<p>cheers,</p>
<p> </p>
<p>Michel</p>
0 -
<p>Hi ,<br>
<br>
I am trying to install BIRT i-Hub F-type , it was successfully installed , by when i tried to run the application its giving me page not found.<br>
<br>
OS config<br>
<br>
Windows 7 (64 Bit)<br>
8 GB RAM</p>
<p> </p>
<p>I am unable to attach the file so pasting my Logs in below</p>
<p> </p>
<div>---START LOG---</div>
<div> </div>
<div> Directory : C:/Actuate/BIRTiHub/BIRTiHub/iHub/data/server/log</div>
<div> File : C:/Actuate/BIRTiHub/BIRTiHub/iHub/data/server/log</div>
<div> Host : AetinsIT-LP18</div>
<div> ID : 5c-b9-01-83-95-63f4-06-69-5d-f3-bcf4-06-69-5d-f3-b800-05-9a-3c-78-000a-00-27-00-00-1854-e8-96-52-29-1c00-05-9a-3c-7a-0054-50-2e-d5-a7-09</div>
<div> Physical Memory : 8083 MB</div>
<div> Virtual Memory : 20260 MB</div>
<div> Platform : Windows 7 Professional</div>
<div> OS Version : 6.1 Service Pack 1</div>
<div> System : 2</div>
<div> System Bound : 2</div>
<div> System Logical : 4</div>
<div> System Threads : 2</div>
<div> Vendor description : Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz</div>
<div> CPU clock speed : 2194</div>
<div> Actuate file version : 23 iHub</div>
<div> Actuate product version : 23 iHub</div>
<div> Actuate file build number : 230A140709</div>
<div> Actuate product build number : 230A140709</div>
<div>Process Affinity : 15</div>
<div>System Affinity : 15</div>
<div>Processor Thread Status : HyperThreading Technology supported & enabled </div>
<div> </div>
<div> Registry keys : </div>
<div> </div>
<div> AC_CONFIG_HOME=C:/Actuate/BIRTiHub/BIRTiHub/iHub/shared/config</div>
<div> AC_DATA_HOME=C:/Actuate/BIRTiHub/BIRTiHub/iHub/data</div>
<div> AC_JRE_HOME=C:/Actuate/BIRTiHub/JRE64</div>
<div> AC_MACHINE_NAME=AetinsIT-LP18</div>
<div> AC_ODBC_HOME=C:/Actuate/BIRTiHub/BIRTiHub/iHub/odbc</div>
<div> AC_SERVER_HOME=C:/Actuate/BIRTiHub/BIRTiHub/iHub</div>
<div> AC_SHARED_HOME=C:\Actuate\BIRTiHub\BIRTiHub/iHub/shared</div>
<div> AC_SYSTEM_NAME=aetinsit_lp18</div>
<div> AC_SYSTEM_SCHEMA_NAME=aetinsit_lp18</div>
<div> ALLUSERSPROFILE=C:\ProgramData</div>
<div> APPDATA=C:\Users\gangadhar\AppData\Roaming</div>
<div> asl.log=Destination=file</div>
<div> CLASSPATH=.;C:\PROGRA~1\IBM\SQLLIB\java\db2java.zip;C:\PROGRA~1\IBM\SQLLIB\java\db2jcc.jar;C:\PROGRA~1\IBM\SQLLIB\java\sqlj.zip;C:\PROGRA~1\IBM\SQLLIB\java\db2jcc_license_cu.jar;C:\PROGRA~1\IBM\SQLLIB\bin;C:\PROGRA~1\IBM\SQLLIB\java\common.jar</div>
<div> CommonProgramFiles=C:\Program Files (x86)\Common Files</div>
<div> CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files</div>
<div> CommonProgramW6432=C:\Program Files\Common Files</div>
<div> COMPUTERNAME=AETINSIT-LP18</div>
<div> ComSpec=C:\Windows\system32\cmd.exe</div>
<div> DB2INSTANCE=DB2</div>
<div> debuglog="C:\Actuate\BIRTiHub\BIRTiHub\.\startiHub.log"</div>
<div> FP_NO_HOST_CHECK=NO</div>
<div> HOMEDRIVE=C:</div>
<div> HOMEPATH=\Users\gangadhar</div>
<div> IHUB_SETUP_HOME=C:\Actuate\BIRTiHub\BIRTiHub\.</div>
<div> INCLUDE=C:\PROGRA~1\IBM\SQLLIB\INCLUDE;C:\PROGRA~1\IBM\SQLLIB\LIB</div>
<div> LIB=;C:\PROGRA~1\IBM\SQLLIB\LIB</div>
<div> LOCALAPPDATA=C:\Users\gangadhar\AppData\Local</div>
<div> LOGONSERVER=\\PENTA-AD1</div>
<div> MSTR_DESK_REGISTRY_FILE=C:\PROGRA~1\MID822~1\MICROS~1\MsiReg_64.reg</div>
<div> NUMBER_OF_PROCESSORS=4</div>
<div> OS=Windows_NT</div>
<div> Path=D:\OraHome_1\bin;C:\Users\gangadhar\Downloads\ODP.NET_Managed_ODAC12cR4;C:\oracle\bin;C:\oracle;D:\instantclient_11_2;D:\instantclient_10_2;C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Java\jdk1.8.0_65\bin;D:\;C:\Program Files\MicroStrategy\MicroStrategy Desktop\DataServices\180_77\64-bit\bin\server;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files (x86)\Skype\Phone\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\140\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\140\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\140\Tools\Binn\ManagementStudio\;C:\PROGRA~1\IBM\SQLLIB\BIN;C:\PROGRA~1\IBM\SQLLIB\FUNCTION;C:\PROGRA~1\IBM\SQLLIB\SAMPLES\REPL;C:\Program Files\TortoiseSVN\bin;C:\Users\gangadhar\AppData\Roaming\npm</div>
<div> PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC</div>
<div> PDF_TRUETYPE_FONT_FOLDER=C:\Windows\Fonts\</div>
<div> PROCESSOR_ARCHITECTURE=x86</div>
<div> PROCESSOR_ARCHITEW6432=AMD64</div>
<div> PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 61 Stepping 4, GenuineIntel</div>
<div> PROCESSOR_LEVEL=6</div>
<div> PROCESSOR_REVISION=3d04</div>
<div> ProgramData=C:\ProgramData</div>
<div> ProgramFiles=C:\Program Files (x86)</div>
<div> ProgramFiles(x86)=C:\Program Files (x86)</div>
<div> ProgramW6432=C:\Program Files</div>
<div> PROMPT=$P$G</div>
<div> PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\;C:\Program Files (x86)\Microsoft SQL Server\140\Tools\PowerShell\Modules\</div>
<div> PUBLIC=C:\Users\Public</div>
<div> SESSIONNAME=Console</div>
<div> SQLRD=C:\Program Files (x86)\ChristianSteven\SQLRD\sqlrd.exe</div>
<div> SQLRDDIR=C:\Program Files (x86)\ChristianSteven\SQLRD</div>
<div> statusfile="C:\Actuate\BIRTiHub\BIRTiHub\.\setup.status"</div>
<div> SystemDrive=C:</div>
<div> SystemRoot=C:\Windows</div>
<div> TEMP=C:\Users\GANGAD~1\AppData\Local\Temp</div>
<div> TMP=C:\Users\GANGAD~1\AppData\Local\Temp</div>
<div> USERDNSDOMAIN=PENTASOFT.MY</div>
<div> USERDOMAIN=PENTASOFT</div>
<div> USERNAME=gangadhar</div>
<div> USERPROFILE=C:\Users\gangadhar</div>
<div> VBOX_MSI_INSTALL_PATH=C:\Program Files\Oracle\VirtualBox\</div>
<div> windir=C:\Windows</div>
<div> windows_tracing_flags=3</div>
<div> windows_tracing_logfile=C:\BVTBin\Tests\installpackage\csilogfile.log</div>
<div> AC_SERVER_NAME=AetinsIT-LP18</div>
<div> AC_SERVER_IP_ADDRESS=AetinsIT-LP18</div>
<div> AC_SOAP_DISPATCH_ADDRESS=AetinsIT-LP18</div>
<div> JAVA_HOME=C:/Actuate/BIRTiHub/JRE64</div>
<div> </div>
<div>
</div>
<div> </div>
<div>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</div>
<div>****0000004916*licensekey.cpp*01183*PRGRM*2017SEP19*15:06:58</div>
<div> Expiration Date : 07/08/2017</div>
<div>
</div>
<div> </div>
<div>****0000004916*pmdfacade.cpp*02590*08000*2017SEP19*15:06:58</div>
<div> Caught ServerException with Error Number : 8104</div>
<div> Localized String : </div>
<div> Parameter: 07/08/2017</div>
<div> Exiting.....</div>0 -
<div>Hi Gagadhar15,</div>
<div> </div>
<div>The logs that you have provided show that the license had expired 2 months ago. The iHub will not allow some of the ihub process to start if the license is expired, which is why the application page cannot be found. Please contact support@opentext.com with a licensing request to speak to our licensing department.</div>
<div> </div>
<div>Please note, we no longer offer iHub F-Type, so you may not be able to recieve an FType license.</div>
<p>Dear <a class="" href="http://developer.actuate.com/community/forum/index.php?/user/68604-jneneman/" title="">jneneman</a></p>
<p> </p>
<p>Thank you for your feedback.</p>
<p> </p>
<p>So we need to have a license version correct me if i am wrong.</p>
<p> </p>
<p>Currently i downloaded the Ihub which is for 40 days trial ( Is it possible to get community version of it) because we need very limited functionality from Ihub .</p>
<p> </p>
<p>Thanks</p>
<p>M. gangadhar</p>
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 144 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 120 Exstream
