BIRT Runtime 4.6 Excel Multi-sheets problem
<p>I was able to generate Excel report with multiple sheets using Page Break Properties in Birt Report Designer 4.6.</p>
<p>However, when using BIRT Runtime 4.6, the Excel report is generated with only one single sheet.</p>
<p> </p>
<p>Any ides regarding this issue?</p>
<p> </p>
<p>Hi,</p>
<p> </p>
<p>I'm having the same issue.</p>
<p>I'm using birt-runtime V <strong>4.4..2</strong></p>
<p> </p>
<p>I try to generate XLS and XLSX files.</p>
<p>The generation seems to be done by the spudsoft emitter :</p>
<pre class="_prettyXprint _lang-nocode">
Jan 27, 2017 10:24:28 AM uk.co.spudsoft.birt.emitters.excel.framework.Logger info
INFO: start:org.eclipse.birt.report.engine.content.impl.ReportContent@279c3e40
</pre>
<p>My RPTDesign files contains Page Break, which is correctly rendered if I generate to another format (PDF for instance).</p>
<p> </p>
<p>Does someone have any idea what might cause this issue ?</p>
<p> </p>
<p>Thanks in advance,</p>
- 108 Developer Announcements
- 53 Articles
- 106 General Questions
- 145 IM Services
- 43 OpenText Hackathon
- 32 Developer Tools
- 120 Exstream
