Analytics
Having trouble getting BIRT Web Viewer to work with IE, Chrome, or Firefox to work.
aasmelash@mta.maryland.gov
<p>Hello Folks,</p>
<p>I am having trouble getting BIRT Web Viewer to work with any of the web browser to work. I can get output in pdf format. However, I can't get the web viewer to work, I get blank screen. I have tried IE, Chrome, and Firefox. I have also tried JRE 1.6 and JRE 1.8. Can you please help?</p>
<p>Thanks,</p>
<p>Abel Asmelash</p>
Virgil Dodson
<p>Hi Abel,<br>
What version of the BIRT runtime are you using... and what server have you deployed it to? If you used birt.war out-of-the-box, then you may need to remove a couple files to get the web viewer to start correctly as talked about here <a data-ipb='nomediaparse' href='
http://developer.actuate.com/community/forum/index.php?/topic/39961-birt-webviewer-exceptions-while-deploying-on-tomcat-85-fail-application-at-context-path-webviewer-could-not-be-started/?p=146848'>http://developer.actuate.com/community/forum/index.php?/topic/39961-birt-webviewer-exceptions-while-deploying-on-tomcat-85-fail-application-at-context-path-webviewer-could-not-be-started/?p=146848</a></p>
