Hi, I when I run "iHub31 Custom Viz Zoomable Circle Packing using D3.js__cwong.rptdesign" via "view report in web viewer" it looks as expected. I am using a mac running high sierra and tried it in different browsers. HOWEVER: when I try to print it as a pdf (from the hamburger menu in the web viewer) I get an error: "The resource of this report is not reachable". The same error occurs when I run the other examples containing custom visualizations.
My colleague is on a windows machine and has the same problem, however a different error is reported: info:eclipse.buildId=M20130204-1200 java.version=1.8.0_25 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=nl_NL Command-line arguments: -os win32 -ws win32 -arch x86_64
the error:
run phantomjs with errors /C:/Actuate3/BDPro/eclipse/plugins/com.actuate.phantomjs.win32_1.0.0.v20150710/libs/phantomjs-1.9.7-windows/phantomjs.exe C:\Actuate3\BDPro\eclipse\plugins\com.actuate.webdriver_1.0.0.v20150710\js\rasterize.js file:/C:/Users/MVANDE~1/AppData/Local/Temp/birtViewer/temp/BirtEngineTmp/spa_2519845603722018111.html C:\Users\MVANDE~1\AppData\Local\Temp\birtViewer\temp\BirtEngineTmp\spa_326029634172165752.png {"bookmark":"_bt_bk_1519834385319","width":816,"timeout":1000,"cookies":[{"domain":"127.0.0.1","name":"JSESSIONID","value":"1lkwb5gm74svlatxb1ayjqypn"}],"height":480} exits with value: 0 ReferenceError: Can't find variable: d3 http://127.0.0.1:64449/iportal/appresource/js/d3-cloud-master/d3.layout.cloud.js:400 http://127.0.0.1:64449/iportal/appresource/js/d3-cloud-master/d3.layout.cloud.js:401 ReferenceError: Can't find variable: d3 file:///C:/Users/MVANDE~1/AppData/Local/Temp/birtViewer/temp/BirtEngineTmp/spa_2519845603722018111.html:79 http://127.0.0.1:64449/iportal/appresource/js/spa/head.js:566 in one http://127.0.0.1:64449/iportal/appresource/js/spa/head.js:782 http://127.0.0.1:64449/iportal/appresource/js/spa/head.js:818 http://127.0.0.1:64449/iportal/appresource/js/spa/head.js:914 in process
what could be wrong and how do we fix this?
What version of the Designer are you using so that I can attempt to replicate the issue?
Hi Clement, OSX: Birt Designer Professional Version: 4.4.0 Build id: v20150206 WIN: Actuate BIRT Designer Professional Version: 4.4.0 Build id: v20150710
Hope this helps
There is a defect with the version of PhantomJS that is included in those versions, when using an external .JS delivered via CDN.
An example of this is using an external D3.js @ http://d3js.org/d3.v3.min.js or http://d3js.org/d3.v4.min.js, or Google Maps @ https://maps.googleapis.com
That older version of PhantomJS is not handling 301 redirects correctly but can handle the same .JS hosted locally.
Workarounds:
OR
A. Close out of the Designer B. Download the latest PhantomJS where redirects are handled @ http://phantomjs.org/download.html C. For Windows based Designer and iHub, navigate to ...plugins\com.actuate.phantomjs.win32_1.9.7\libs\phantomjs-1.9.7-windows D. Rename phantomjs.exe to phantomjs.exe.bak E. Copy phantomjs.exe from the ZIP in Step 1 (under phantomjs-2.1.1-windows\bin) to the directory in Step 2 F. Restart the Designer
