Parse XML using Rhino included E4X. Much easier than using SAX or DOM.
Options
Clement Wong
E mod
It’s very simple to parse XML in BIRT scripting using Rhino’s included extension, E4X (https://developer.mozilla.org/en-US/docs/Archive/Web/E4X/Processing_XML_with_E4X). With E4X, XML is a primitive and is easy to access. So there’s no need for Java SAX and DOM packages.
The attached example retrieves an RSS feed from ESPN’s Top Headlines using a Scripted Data Source. Here are a few highlights, and look at the fetch event and you’ll see XML elements are accessed via dot notation.
This example was tested in commercial BIRT iHub 3.1 and OS BIRT 4.4.2, and it should work in earlier versions of BIRT. E4X was removed from Rhino in 2014, but these versions of BIRT still include the version of Mozilla Rhino JavaScript which still has E4X.
beforeOpen importPackage(Packages.java.io); importPackage(Packages.java.net); var inStream = new URL("http://sports.espn.go.com/espn/rss/news").openStream(); var inStreamReader = new InputStreamReader(inStream); var bufferedReader = new BufferedReader(inStreamReader); var line; var result = ""; while ((line = bufferedReader.readLine()) != null) result += line; inStream.close(); //FOR DEBUG, THIS WORKS ONLY IN COMMERCIAL BIRT //logger = java.util.logging.Logger.getLogger("birt.report.logger"); //logger.warning (result); //Remove the first line <?xml version="1.0" ?>" to make it well formed XML result = result.replace(/<\?[^>]*>/g,""); rss = new XML(result); totalItems = rss.channel.item.length(); fetch if( currentrow >= totalItems ){ return false; } row["title"] = rss.channel.item[currentrow].title.toString(); row["description"] = rss.channel.item[currentrow].description.toString(); row["link"] = rss.channel.item[currentrow].link.toString(); row["pubDate"] = rss.channel.item[currentrow].pubDate.toString(); currentrow += 1; return true;
Warning
No formatter is installed for the format ipb
- 109 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 123 Exstream
