Here is a very simple example of BIRT connecting to ElasticSearch using a Scriped Data Set. This could also illustrate connecting to a REST based data source with a JSON result set.<br />
The three events were added:<br />
Data Source > Open
Make a query request to ElasticSearch<br />
Save the results in a JSON variable
Data Set > Open
Reset the row counter to zero
Data Set > Fetch
Create a row of data from ElasticSearch for each “hitâ€<br />
Set the output column field values from the JSON result set<br />
Stop when total hits are reached
Place the helper JavaScript, “json.jsâ€, into the root of the project folder.<br />
Note: If you are using BIRT 4.5.0, it has built-in JSON support so you don't need the helper JavaScript file, "json.js", in the root of your project folder. The difference between the two designs in the ZIP is that the one for pre-BIRT 4.5.0, there is an external Resources reference to "json.js", and the one for 4.5.0 does not have it. If you don't have it in pre-BIRT 4.5.0, when attempting to run the report, you will see an error like ... ReferenceError: "JSON" is not defined.
