Adding Users and Groups functionality to a module. Help?
George_Sutterley_(TracorAdmin_(Delete)_1432564)
Hello, I am in the process of creating a module that needs to be able to add Users and Groups, much like project participants. I have already found out that this is no easy task. I'm thinking that I'm going to use LAPI and java. Can someone point me in the right direction for going about this? Thanks
Robert_Davies_(unlondonadmin_-_(deleted))
Hi George.You're in luck. The users part of LAPI/Java seems to work better than the rest of it. My experiences with LAPI have not been happy overall and I'd advise you to treat the documentation and examples with caution.I've attached to the an area of the Knowledge Centre where you should find the application I wrote for bulk loading users into a Livelink server. This utilizes LAPI/Java and is simple enough to be easily canibalized.If you want any more specific advice please post another message here.Best regards/matt.
