date datatype problem in using lapi with java (successful send)
Richard_Ma_(mtrcadmin_-_(deleted))
hi all,lapi and livelink: 8.0.2os: winnt sp3java: jdk1.1.8When I use LAPI with JAVA, I get an error which seem odds.Here is a small JAVA program to reproduce the problem:The error is:get(name) not implemented for this datatypecom.opentext.api.LLIllegalOperationException: get(name) not implemented for this datatype at com.opentext.api.LLInstance.get(LLInstance.java) at com.opentext.api.LLValue.toValue(LLValue.java) at com.opentext.api.LLConnect.unMarshall(LLConnect.java) at com.opentext.api.LAPI_DOCUMENTS.CreateObjectEx(LAPI_DOCUMENTS.JAVA) at qq.main(qq.java:56)It seem that something is not implemented in the Date datatype.So, I want to ask, is there any work arround of this problem? or is there any method to do the same job?I only want to do is create a task list and a task with preset start date.thx a lotWaimailto:leungkw@mtrcorp.com
Kent_Jordan_(KJordan_(Delete)_792853)
I had the same error message when I forgot to check that the opentext.ini file was set to wantLAPI=TRUE. After I made the change to ini file everything worked ok from that point on with the testLAPI.java app.
