Problem using FetchRendition method
Patrick_Meissner
I am trying to add a method to an existing Java program which utilizes the Java LiveLink API. There is an existing method to fetch a document, using the FetchVersion method, which works great. I modeled another method after it, using the FetchRendition method. The API calls are identical, except that FetchRendition contains the added parameter for the rendition type. I am passing in the string "PDF" as per the API documentation.When running the program, I get the following exception thrown:"com.opentext.api.LLUnknownFieldException: LLValue unknown field name: FileAttributes."The FetchVersion works fine when trying to fetch the same document. Does anyone have any experience or insight into this error?Thank you,-- Ben Eadington
x-scoruser8_-_(deleted)
I'm getting the same exception with FetchVersion(). Does anyone know how to avoid this exception.Basically I'm adding a file using AddDocument() and then attempting to get it back out with FetchVersion(). Is there anything else I need to do to the document before I can fetch it?
