Problem with LL_Uninitialize
Hans_De_Beuckelaer_(x-hdebeuck_-_(deleted))
When I call LL_Unitialize at the end of my program (VB), it returns the attached error and the complete application crashes.The dll's that I use are from version 9. In the past I used those from version 8.1.5.. and it didn't give any problem.Can somebody help me please.Regards
Chad_Gage_(kofaxuser3_-_(deleted))
I had the same problem. This is definitely a LiveLink bug. It happens the 2nd time you call Uninitialize, right? And it kills the program? I talked to the tech support guy and he said, it is because you should not call uninit twice. Therefore, the workaround is just never call LL_Uninitialize. Yeah, I know that sounds dumb, but that's the only way to not get this problem. Optionally, you can move all the code off into a separate COM EXE, and forcibly load and unload it each time so that it is never called a second time in the same instance of the LAPI DLL's. I asked the tech support guy to write it up as a bug, but he said that's "as designed". Hope that helps.--Matt
That's indeed what I did, don't call LL_Unitialize. And I didn't have the problem again.Thanks for your reply Matt.Hans
Anton_Kejr_(sglcadmin44_-_(deleted))
Hi Chad,that was a more than important information for me !!Since ages I'v been struggling with several crashes I didn't understand at all. Not all the time though ;-)But all my problems are gone now. Thanks for sharing !!Best regardsAnton
