I have a Problem with LL_CreateFolder in C++
Thomas_Blume
Hello,I work with Livelink 9001. I try to add Subfolder in C++. In Visual Basic it works. But I suppose the initialisation of the variables isn't right.I suppose the last parameter is the wrong one!This is an example:LL_CreateFolder(session, Volume, parentID, "New Folder2", &value)session is clear - I hopeVolume - ID of Enterprise Workspace in this case -2000parentID - in this case for example - 13304if ( LL_ListObjects(session, parentVol, parentID, NULL, sName, LL_PERM_SEE, objects) == LL_OK ) { if ( LL_ValueGetLength(objects, &length) != LL_OK ) { DebugMsg("ERROR: LL_ValueGetLength(objects, &length) failed" ); return false; } if ( length == 1 ) // Objekt { // Get parentID if ( LL_TableGetInteger( objects, 0, "ID", &parentID ) != LL_OK ) { DebugMsg("ERROR: LL_AssocGetInteger( tmp1,'ID',&parentID ) failed" ); return false; } }"New Folder2" is to create.The last parameter:!LLVALUE value;LL_ValueAlloc (&value);Who can help me???Thanks in advanceAndreas
There are no comments yet
