Setting Attribute Values Does Not Work
Lance_Griffith_(SPPARAdmin_(Delete)_2261001)
I have been trying to set the values of specific attributes in a category for a particluar document (node object). I follow the API documentation for Livelink 9, but cannot seem to set the values. It is easy enough to retrieve the current value, but the sets do not appear to work. Any suggestions?
eLink User
Message from Sathya Saravanan via eLinkWhat is the data type of the attribute you are using ? and what LAPIfunctions are you using ?-----Original Message-----From: knowledge@opentext.com [mailto:knowledge@opentext.com]On Behalf OfeLink Discussion: LAPI DiscussionSent: Tuesday, March 05, 2002 11:07 PMTo: eLink RecipientSubject: Setting Attribute Values Does Not WorkSetting Attribute Values Does Not WorkPosted by SPPARAdmin on 03/05/2002 02:06 PMI have been trying to set the values of specific attributes in a categoryfor a particluar document (node object). I follow the API documentation forLivelink 9, but cannot seem to set the values. It is easy enough toretrieve the current value, but the sets do not appear to work. Anysuggestions?[To reply to this thread, use your normal e-mail reply function.]============================================================Discussion: LAPI Discussion
https://knowledge.opentext.com/knowledge/livelink.exe?func=ll&objId=765428&objAction=viewLivelink
Server:
