Strange problem with CreateObjectEx
insystems_rnd_insystems_rnd
My code creates a folder called 'testFolder' with CreateObjectEx, and then uses the Enterprise search broker to make a search for that object using ApplyQuery. Even if the first call has finished OK and the folder object is there, the second call won't find it. Any suggestions on what may be wrong in this sequence of calls?
eLink User
Message from Kevin Ward via eLinkApplyQuery searches for data stored within Livelink's index. When newobjects are added they run through a dataflow to extract and index the data.Until this process is complete, the new object will not be returned in theresults from ApplyQuery. This will generally take several minutes.If you wish to execute queries on the Livelink Database instead of theindex, consider using RunReport. RunReport is available in Livelink 9.1.xand executes a LiveReport stored within Livelink. LiveReports would returndata on your new object immediately after CreateObjectEx has completedsuccessfully.Kevin-----Original Message-----From: eLink Discussion: Development Discussion[mailto:development@elinkkc.opentext.com]Sent: April 7, 2003 11:43 AMTo: eLink RecipientSubject: Strange problem with CreateObjectExStrange problem with CreateObjectExPosted by insysrnd on 04/07/2003 11:30 AMMy code creates a folder called 'testFolder' with CreateObjectEx, and thenuses the Enterprise search broker to make a search for that object usingApplyQuery.Even if the first call has finished OK and the folder object is there, thesecond call won't find it. Any suggestions on what may be wrong in thissequence of calls?[To reply to this thread, use your normal e-mail reply function.]============================================================Discussion: Development Discussion
https://knowledge.opentext.com/knowledge/livelink.exe?func=ll&objId=786303&objAction=viewLivelink
Server:
