Urgent Help - Searching for Users using LAPI
unknown
I am trying to search for users based on users LASTNAME. I am getting the following Java Exception.get(name) not implemented for this datatypecom.opentext.api.LLIllegalOperationException: get(name) not implemented for this datatype at com.opentext.api.LLInstance.get(LLInstance.java:77) at com.opentext.api.LLValue.toValue(LLValue.java:800) at com.opentext.api.LLConnect.unMarshall(LLConnect.java:303) at com.opentext.api.LAPI_USERS.ListUserGroup(LAPI_USERS.java:914) at GetUserInfo.main(GetUserInfo.java:106)I am not sure where I am doing wrong. I am new to LAPI and any help will be hightly appreciated. I am attaching the code here.Thanks & Regards,Satish
Geoff_Price
I'm getting the same error. I looked at your code and I set mine up pretty much the same, but I'm having no luck getting it to work? Anyone have a suggestion?Thanks,Geoff Price
Krishnankutty_Nair
I believe the parameter declaration type is wrong.this is something that I think will work.I belive I worked on the above example and made it work thru this.Please try and see if this works
