LAPI SDK for Records Management Module and Physical Objects
Sandra_Popovic-Ovcina_(intato017_-_(deleted))
Where can I find LAPI SDK for RM and Physical Objects to download? We have 2.8.0 version of both modules.I've found only the guide: Livelink_Records_Management_and_Physical_Objects_API_Guide.pdfThank you in advance,Sandra
Knowledge_Center_Administrator
Hi there,Both modules (RM and Physical Objects) ship with the API, so there is nothing additional for you to download. The API documentation simply describes the RM and Physical Objects API functions and they should be used in the same way as the rest of LAPI.There is a specific RM and Physical Objects discussion that you may wish to post to if you have additional specific questions as it is possible that your questions will be less applicable to LAPI and more specific to the RM / PO world. Here's the link to that discussion:
https://knowledge.opentext.com/knowledge/llisapi.dll?func=ll&objId=2589561&objAction=view&sort=nameRegards,Dave
Thank you for this.I am already using RM and PO discussion board and found it quite useful. It is only that I do not always get answers...Best wishes,Sandra
Hi Sandra,The RM discussion has a very high response rate from the product development and product management group at Open Text. I'm sorry if some of your questions were missed.However, please keep in mind that KC discussions are monitored, not moderated. If your question or problem is urgent, or if you would specifically like a formal response from Open Text, you should contact your local Open Text Customer Support office directly.Please refer to the following listing of Open Text Customer Support Office Locations:
http://www.opentext.com/services/contact_us_support.htmlRegards,Dave
