Using LAPI SDK with prior Livelink Versions
Matt_Miranda_(EAFBMattMiranda_(Delete)_2184030)
I am building a LAPI application that enables a user to mass delete workflow's. The only function that gets called is 'deleteWorkflow()' My Livelink Server version is 9.1 SP2, but I would like to use the Livelink 9.2 SDK (because of the .NET compatibility). Does anyone forsee any problems with this? I would think no, but I may not be aware of any other issues.
John_Shoun
The configuration you are suggesting is not supported by Open Text, but it seems to work OK.We've rebuilt all our LAPI applications (Java) with the 9.5 libraries and have not had any problem interfacing to 9.1 SP3 servers. As long as you don't call functions defined in 9.5 that don't exist in 9.1 you are relatively safe.
