Error when trying to upload a document using LAPI java using input stream.
S_Swaminathan_(maninfoadmin_-_(deleted))
I am trying to add a document into Livelink using input stream.I am using LPAI 9.1.3.It is giving me the error. Both add document and create version methods are giving errors. Below error is for createversion method.LivelinkUtil.java:524: CreateVersion(int,int,java.lang.String,com.opentext.api.LLValue) in com.opentext.api.LAPI_DOCUMENTS cannot be applied to (int,int,java.lang.String,java.io.InputStream,int,com.opentext.api.LLValue,com.opentext.api.LLValue).I have used the method given in documentation. Is it that I can not use input stream to upload document into Livelink? Or the createversion using input stream can not be used with LAPI_DOCUMENTS?If anybody has done this , can you pls share the code?pls help.
There are no comments yet
