LL_GetNumberOfObjects problem. Please HELP!
Shawn Borden
Hello!I am successfully conecting to server by LL_SessionAllocExThen calling LL_AccessEnterpriseWS also everithing is OK!When I am calling LL_GetNumberOfObjects, it sais me thet there are 40 chidren. When I am printing arrey from LL_ListObjects ,children 0 till 8 are ok(I can see all 8 in te web). ),but children from 9 to 40 are the same as child number 8.Why LL_GetNumberOfObjects gives me more children then there are actually??? Is there another function instead of LL_GetNumberOfObjects that I can use to get the right number of cildren?
Tina_Wang
Sounds like it could be a potential bug. I would recommend opening up a ticket with support.
Howard_Pell
Message from Howard Pell <
hlpell@opentext.com
> via eLink
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">eLink
Hello,
Please notice the remarks section of the LL_GetNumberOfObjects function - "
The
GetNumberOfObjects
function can be performed on the following types of objects: channel, compound document, discussion, folder, project, and task list."
That is, it does not support workspaces.
In the LAPI training course I use the following code as an example and exercise:
In Visual Basic (which I assume you are using)
I first get the volumeID (volid) and the nodeID (objid) and then
status = LL_ListObjects(session, volid, objID, "", "", LL_PERM_SEE, childitems)
If status = LL_OK Then
'How many items are in this folder?
status = LL_ValueGetLength(childitems, length)
For i = 0 To length - 1
'Test every item in the folder
status = LL_ValueGetIndexValue(childitems, i, child)
status = LL_ValueGetFieldValue(child, "subtype", tmp1)
status = LL_ValueGetInteger(tmp1, subtype)
If subtype = LL_FOLDERSUBTYPE Then
I hope this helps
Howard
Howard Pell
Senior Technical Educator
Liaison, Special Projects
Open Text Corporation
www.opentext.com
(519) 888-7111 Ext. 2203
Education is for improving the lives of others and for leaving your community and world better than you found it.
- Marian Wright Edelman
eLink Discussion: LAPI Discussion [mailto:lapi@elinkkc.opentext.com]
Sent:
Tuesday, October 11, 2005 5:27 PM
To:
eLink Recipient
Subject:
Posted by
hatchsupport
(Support, Hatch) on 10/11/2005 05:22 PM
Hello!
