Problem using attrSetValues with some field types
steve_lindahl
Hi,I've written a small LAPI program using VB.NET. It is supposed to load metadata from an external SQL Server table. I've run into some problems with the use of attrSetValues due to my lack of experience. I've had good luck with Text Fields and Text Popups, but I've run into trouble setting Date Fields and Text Popups which are not locked and have a max number greater than one. I've kept attrValuesPath set to "" and attrValues set to the value I?m trying to put in those fields, either a date or a string. I was hoping someone might have a suggestion I could try.Thanks.
There are no comments yet
