Problem with oracle output and LiveReport
Uldis_Silovs
Hello everyone!I'm using Livelink with Oracle db.I need to prepare and then execute a complicated SQL query.I'm preparing this query within PL/SQL block (or this can be done also in a stored procedure).For example:declare sString varchar(255);begin--query will be more complicated with different calculations within this block select Name into sString From Dtree Where DataID=2000; dbms_output.put_line(sString );end;I receive results from SQL command line, BUT no results when I run this block in LiveReport.Any ideas?
Appu_Nair
I think it could be because dbms_output.put_line(sString ); is an SQLplus package that LiveReport does not know about.If possible create a temporary table and re-run this.
Tim_Hunter
Look into a table function maybe? I don't understand what you are trying to accomplish.
