Hi all,
I am having a problem related to createNodeResponse. The structure for METADATA is as follows:
As we can see, there is no "Values" element defined under metadat -> AttributeGroups -> Values
But, I get a response which has this "Values" tag under Values which is not defined in the structure and it is causing an exception(Unmarshal exception since the defined structure doesn't have "Values" element. The response is:
<ns2:AttributeGroups>
<ns2:DisplayName>zWorkflow Control</ns2:DisplayName>
<ns2:Key>446232.1</ns2:Key>
<ns2:Type>Category</ns2:Type>
<ns2:Values xsi:type="StringValue" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Description>Workflow Activator</Description>
<Key>446232.1.2</Key>
<Values>Review</Values>
</ns2:Values>
</ns2:AttributeGroups>
Can you please suggest how to get around this problem.
Kapil
