Hi Forum
I am hoping someone can help me here as i do not have LLbuilder or much oscript experience .
I was looking for a way to solve the following problem , i have a workflow and i wanted the user to be prompted to enter a comment when they rejected a workflow step.
now i found on the workflow forum an entry from 2009 where someone had a simple module written that allowed you to handle this via an event script, so i installed on a wintel VM and it works really good, but my problem is when i try to install on our envronment which sits on a solaris kit the module says it is having trouble at the " witwflowes.configure " stage in the .ini file.
I do not really know where the problem is here and find it strange that it works fine in windows ?
Anyone got any suggestions here as to why this is ?, i am attaching the module ...
Regards
Mike.
