I am experiencing 2 issues if anyone has any comments/assistance...
Using Content Web Services I am attempting to create a document with one or more categories, where some of the attributes of each category are not used (and defined as not required).
Firstly I am seeing that StringValue based category attributes are displaying in the CS front-end without the associated data-entry box when the document and metadata are saved.
To get around this, I have to initialise each StringValue attribute to an empty string, which seems strange. (see code snippet below)
Secondly, when initialising each StringValue based category attribute, an error of "One or more invalid values for attribute {attribute} were provided." is thrown upon document creation where the attribute is defined as a "Table Key Lookup". This is the same even if an entry is added to the lookup with an empty string ("") or space (" ").
Has anyone else expreienced this or know of a workaround or fix...?
These issues are being experienced using CS 10.5 .Net Web Services where CS is using Oracle as it's RDBMS.
metadataCategory = clientBlock.documentManagementClient.GetAttributeGroupTemplate(ref clientBlock.docAuth, "Category", systemCategories.FirstOrDefault(c => c.DisplayName == categoryName).Key);
string fieldType = null;
for (int attributeCount = 0; attributeCount < metadataCategory.Values.Length; attributeCount++)
fieldType = metadataCategory.Values[attributeCount].GetType().ToString();
fieldType = fieldType.Substring(fieldType.LastIndexOf(".") + 1);
if (fieldType == "StringValue")
ContentServerConnectorNS.DocumentManagement.StringValue stringValue = metadataCategory.Values[attributeCount] as ContentServerConnectorNS.DocumentManagement.StringValue;
stringValue.Values = new string[] { "" };
