Hi guys,
I came across this problem. eclipse will not load moudle explorer if patch pat105000025 is installed in patch directory. problem was solved after removing this patch
Just sharing this infor
In particular, I believe it’s the en-dash after “Error deleting a Custom Column” that triggers the issue.
