Problems with "path" field from "createUniqueName" function in wsdl via SOAP
Hi all!
I've done a Content Script to make a SOAP call to the wsdl. This script serves to call the function "createUniqueName" and the xml needs 3 fields:
- uniqueName: the name of the uniqueName
- path
- name: the name of the folder
I tested the script on a subfolder of "Enterprise", writing in the "path" field just "Enterprise" and it works. The problem is that I need to launch it on subfolders at deeper level. Using Content Script, I usually write the path in the format “Enterprise:SubFolder1:SubFolder2: … :SubFolderN”, but it doesn’t work in this case.
Do you know the right format for this call?
Thank you in advance :)
Pietro
- 123 Developer Announcements
- 54 Articles
- 156 General Questions
- 151 Thrust Services
- 57 Developer Hackathon
- 38 Thrust Studio
- 4.2K AppWorks
- 9K Extended ECM
- 919 Core Messaging
- 84 Digital Asset Management
- 9.4K Documentum
- 34 eDOCS
- 193 Exstream
- 10 XM Fax
- Follow Categories
