Help needed on left and right double quotation conversion
Hi Team,
As part of business requirement, Documentum workflow method is converting HTML to PDF using iTextPDF API.
Generated PDF contains some special characters whenever tried to convert left(“) and right(”) double quotation marks. We seen above issue in DCTM 21.2 and however, it is converting without any issue in DCTM 16.4 setup.
HTML file(with left & right double quotations)
PDF(post conversion)
Is there any issue on encoding in DCTM 21.2 ? If yes, please share the resolution steps.
Any help would be highly beneficial for me!!
Thanks and Regards,
Ganesh Kumar
What makes you think Documentum has anything to do with it? This is done in your code. You probably relied on default Java encoding and that may have changed between your two systems.
0 -
FYI… the embedded opensource version of iText is going to be replaced soon, in a future release of Documentum.
Kyle Pettit
Documentum D2 Product manager0
- 111 Developer Announcements
- 49 Articles
- 102 General Questions
- 123 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 124 Exstream
- 1 XM Fax
