JobOption Element does not work in xPression RESTful Services for Batch
Hi all,
I would like to use the RESTful Services to trigger a Batch, and I found the service url "http://your_server:your_port/xFramework/restful/services/job/start" could be done it. After testing the function, i found that the parameter "-o" in the "<JobOption>" element didn't work, but it could work with command line when running the same job setting via BatchRunner.bat.
And then, I tested another parameter "-q" to generate a new list of the data sources, it didn't work yet.
Another question for this part, this API will return a JobRunID after the request is successful. But the value is different between the JobRunID in xDashboard.
Job RunID from Response Content:
2323011320007171342279479908504
Job RunID from xDashboard:
2323011320008171342281648808504
Could you please help me to support it? Thanks.
Answers
This function can run the Job successful with the default data source, but i want to override the default data source of a batch run. Thanks.
- 111 Developer Announcements
- 49 Articles
- 103 General Questions
- 123 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 123 Exstream
- 1 XM Fax
